It is currently Fri Mar 27, 2026 1:16 pm
[ 4 posts ] |
removing ujoint from 23 GD longtail
rummya87
I took the motor off of the frame, and I'm trying to get the joint off of the crankshaft. I tried to knock the key out like i did for the driveshaft side but it ain't going, I want the joint completely off of the motor/crankshaft not just the u joint out of the yokes. I searched for this and couldnt find any answers
| Wed Jul 28, 2010 3:33 pm |
chjohnson622
Joined: Fri Feb 13, 2009 4:20 pm Posts: 51 Location: SE Texas
 Re: removing ujoint from 23 GD longtail
I put a 3 jaw pulley puller and heated the yoke till it was red, and that did not work. The last time I removed the yoke on the motor side I carefully cutting it off. It was a B#@*^. Good luck
_________________ We all suffer 1 of 2 things; The pain of Discipline or the pain of Regret. Don't Regret
| Fri Jul 30, 2010 3:19 pm |
Mark F. Cheney
Joined: Sat Mar 07, 2009 9:44 am Posts: 154 Location: Bountiful, Utah
Both the UJ yoke and the crankshaft are both carbon steel and liable to rust together because of the wet environment. So soak the thing in some kind of rust loosen all from the auto parts people for a while. It will make a difference.
Mark F. Cheney
_________________ on the Great Salt Lake marsh
| Sat Aug 07, 2010 8:36 pm |
jesse63b
Joined: Thu Jun 24, 2010 7:40 pm Posts: 5 Location: LaCrosse, Wi.
if and when you get it off put on some anti seize to keep it from rusting together again
_________________ 15 Ft. War Eagle with a 23 HP GD LT
| Sun Aug 08, 2010 6:16 am |
[ 4 posts ] |
