It is currently Tue Apr 07, 2026 12:06 pm
Reply to topic  [ 8 posts ]
 Pressure Lubricator Question
Post Pressure Lubricator Question
I have the Alemite Pressure Lubricator on my Long Tail. Recently it has been oozing grease from under the cap while I am running. What do ya'll think is causing this?
I currently have the "lightest" spring in the lubricator. Could this be the problem?
Sat Dec 17, 2011 8:48 pm
The seal that pushes the grease down in to the shaft housing is bad. Just replace the whole thing, no grease should be between the cap and the seal.
Sat Dec 17, 2011 8:55 pm
Post Re: Pressure Lubricator Question
Thanks.
Sat Dec 17, 2011 9:18 pm
Fri Dec 23, 2011 7:46 pm
There is a seal around the plunger in the lubricator.
Fri Dec 23, 2011 9:04 pm
fill the cup max 3/4 full also
17*38 Klibert 23GDLT
Fri Dec 23, 2011 9:28 pm
^x2. If you fill it all the way to the top, when the grease in the shaft heats up it either gonna blow through the bushing seals or take a dump in the lubricator.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Dec 23, 2011 9:32 pm
thanks
Sun Dec 25, 2011 8:39 am
