Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Problem with brand new lt
I got a Honda gx390 with a Thai longtail. Just fired it up and every time I tilt the prop down the motor stalls. Prop does not have to be in the water to stall. I have enough gas in it. Is there any kind of modifications I have to do with the float? Thanks for any info
_________________ 23 swomp/ 1542 tracker
| Wed Aug 08, 2012 1:36 pm |
Trousertrout
 Re: Problem with brand new lt
Never mind guys. Didn't realize that because I was tilting it so far down to a tub of water on my driveway that is was messin with the float
| Wed Aug 08, 2012 2:05 pm |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
It proly wasn't the floats it was the mercury sensor killing it when u leaned it too far
| Wed Aug 08, 2012 2:08 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
_________________ 35 GTR - 1754 Extreme
| Wed Aug 08, 2012 2:55 pm |
txmudcutter
| Wed Aug 08, 2012 3:20 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
Mercury sensor is only an issue when trying to start the motor, it doesn't affect anything when the motor is running. If that were the case, every time someone with a Go Devil trims down to dig in the mud, the engine would kill...[/quote]
Dont know about all motors but my honda and my clones have the mercury switch tied to the terminal ground circuit. they are there to protect the engine from running at an excessive angle.
| Wed Aug 08, 2012 5:25 pm |
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
how bout low oil sensor. too much of an angle will put sensor out of oil. does on my kohler
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
| Wed Aug 08, 2012 9:14 pm |
Woodiebuster
Yes, check your oil.
| Wed Aug 08, 2012 10:26 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Wed Aug 08, 2012 11:16 pm |
txmudcutter
| Thu Aug 09, 2012 5:58 am |
