It is currently Sun Apr 05, 2026 11:28 pm
[ 4 posts ] |
Beavertail Kohler 27hp LT
dreamweav9
I currently have a beavertail Kohler 27hp LT, and have had troubles for TWO seasons now with the key between the shaft/u-joint slipping and causing damage or coming out all together. really becoming a hassle and am just wondering what you guys have done to solve this problem, or if you haven't had any problems with your Beavertails
| Mon Dec 03, 2012 8:24 pm |
Buzz Killington
 Re: Beavertail Kohler 27hp LT
Weld it to the u joint
B. MacDonald
| Tue Dec 04, 2012 5:49 am |
Rendon_6
Joined: Sat Jun 04, 2011 12:45 pm Posts: 81 Location: Hooper, Utah
I machined my own shaft and when I did the key way I left about 1/8 of metal on the wall so the jetway could not come out. Instead of a slot it's like a oval so no open ends.
| Tue Dec 04, 2012 3:41 pm |
KCM
Joined: Sat Jan 17, 2009 3:39 pm Posts: 57 Location: South of the Mason Dixon Line
Your problem may not be the u-joint. Check for bent shaft.
Also you can tap a 1/4 hole in side of u-joint into shaft and use a set screw.
_________________ Home made boat with a 32 PD SS FPR
| Tue Dec 04, 2012 7:37 pm |
[ 4 posts ] |
