It is currently Wed Apr 08, 2026 7:16 pm
Reply to topic  [ 4 posts ]
 Beavertail Kohler 27hp LT
Post Beavertail Kohler 27hp LT
I currently have a beavertail Kohler 27hp LT, and have had troubles for TWO seasons now with the key between the shaft/u-joint slipping and causing damage or coming out all together. really becoming a hassle and am just wondering what you guys have done to solve this problem, or if you haven't had any problems with your Beavertails
Mon Dec 03, 2012 8:24 pm
Post Re: Beavertail Kohler 27hp LT
Weld it to the u joint
B. MacDonald
Tue Dec 04, 2012 5:49 am
I machined my own shaft and when I did the key way I left about 1/8 of metal on the wall so the jetway could not come out. Instead of a slot it's like a oval so no open ends.
Tue Dec 04, 2012 3:41 pm
Your problem may not be the u-joint. Check for bent shaft.
Also you can tap a 1/4 hole in side of u-joint into shaft and use a set screw.
Home made boat with a 32 PD SS FPR
Tue Dec 04, 2012 7:37 pm
