It is currently Fri Apr 03, 2026 10:15 am
Reply to topic  [ 6 posts ]
 Did I over grease?
Post Did I over grease?
I'm new to mud motors and have just bought a GD 23hp LT. I have run the new motor about 2 hours then greased it. I thought that I applied a small amount of grease but now I have a small amount of grease coming from the Upper Bearing. Is this normal or did I screw up?
Tue Jan 08, 2013 12:34 am
Post Re: Did I over grease?
Wipe it up. Read your owners manual on how much grease to use. Doubt you did any damage.
Tue Jan 08, 2013 2:16 am
Roger that...Red Sticky #2 greese works best for me.
Check out "Joe Guide hunting videos" on YOUTUBE...
Tue Jan 08, 2013 2:43 am
I have a GDLT and I grease that fitting until a little comes out all the time. I thought it was designed like that. Thats how I've been greasing similiar fittings like that for years. When you hit the other fitting with the reservior, I make sure that I don't overfill it. Seems like GD manual says NOT to fill that one until it comes out of the cup. I've also noticed that I rarely need more that a shot or two from the grease gun to get that one where I want it. I try to keep it around 3/4 full in the cup at all times.
Tue Jan 08, 2013 7:28 am
Thanks for the help
Wed Jan 09, 2013 9:36 am
If the seal is installed correctly it is oriented so that grease is not locked in and will flow out.
Wed Jan 09, 2013 9:47 am
