It is currently Fri Apr 03, 2026 10:16 am
Reply to topic  [ 18 posts ]
 how tight should the prop be
Post how tight should the prop be
Mine has a little play i can turn it with my hand, reason i ask is i turned my gov. Up abd it changed nothing i still only get 2850 in the water.... once again thanks
Sun Jan 13, 2013 7:27 am
Post Re: how tight should the prop be
Dont know about longtails but dont think you should have any play. It should tighten its self when you run it. Ya might want to take it off and see if the treads on the shaft are striped.Just dont sound right to me.
Sun Jan 13, 2013 7:48 am
Me either, just tryin to figure this thing out ducks def. Aint flyin today
Sun Jan 13, 2013 7:50 am
Have you tryed to tighten it ?
Sun Jan 13, 2013 8:00 am
Just did im about to test it
Sun Jan 13, 2013 8:04 am
Do you have a pin though the back lock nut ? I had to do that on my 1st longtail. That might be the problem is the nut is backing off.
Sun Jan 13, 2013 8:07 am
its supposed to have about 1/4 of a turn of slack
Sun Jan 13, 2013 12:08 pm
I have a gdlt 16. The manual says it should have some slack. About once a year I take the wheel off and never seize the threads. After running it the prop will be tight. After I get home and grease my motor before storing. I start it up and bring it to governor speed and then turn the key off. This sudden stop with the momentum of the wheel loosens it up.
Sun Jan 13, 2013 1:32 pm
Thanks guys i could turn it almost one full revolution both ways i have it down to a quarter now, done some adjusting on the cav plate i have it running 17mphto on gps with two people dog 4 doz decoys on a 1448rivited lowe but still only turninng 3000rpm
Sun Jan 13, 2013 3:16 pm
It is a 27hp kohler
Sun Jan 13, 2013 4:42 pm
What are your rpms out of water?
Sun Jan 13, 2013 4:43 pm
4200
Sun Jan 13, 2013 5:52 pm
Then I would say if you had your prop adjusted to bring your in water Rpms closer to 3300-3500 your speed would increase. Depending on what you running in, as your prop wears a lil your speeds might go up.
Sun Jan 13, 2013 7:07 pm
But with the speeds you posted, I wouldn't change a thing.
I was rather impressed with that speed myself suprised me when my cousin showed me the gps, my concern with the rpm i guess is because the engine seems to be bogged
Sun Jan 13, 2013 7:51 pm
If your governer is not kicking in, it is bogged. Whether 2500 rpms or 3500 rpms.
Sun Jan 13, 2013 8:38 pm
Should i get a smaller prop,
Sun Jan 13, 2013 8:46 pm
I wouldnt with the performance you getting. It will wear with use and rpms will work there way up.
Sun Jan 13, 2013 8:53 pm
