It is currently Fri Apr 10, 2026 7:10 am
[ 6 posts ] |
Bstandfuss
 Throttle cable question
Got a duromax 16 xpe on a home build i am working on. Want to makr sure i have i have throttle hooked up right. Any one have one they can send me pics of how they run it.
Also how do you guys attache the cable to the handle.
| Sun Aug 04, 2013 8:10 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: Throttle cable question
loosen the throttle arm and attach it through holes on the back of the arm (the bracket is sometimes hard to get to with the air cleaner and gas tank in the way). Might also need to get a spring to help act as a return. Run it to a clutch lever from one of those chinese ATV's, they can easily be ordered for $15 online.
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Sun Aug 04, 2013 11:22 pm |
Bstandfuss
Should of clarifed. Do you guys use cable tie to hold the cable in place what is best
| Mon Aug 05, 2013 11:53 am |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
On Briggs motors theres a clamp that holds the Cable. I don't know what that motor has but it should have something. I dont think zip ties are going to hold.
_________________ We ant just mormons and polyganists we got rednecks too
| Mon Aug 05, 2013 1:42 pm |
Bstandfuss
I was thinking some thing like a guide i can screw into the motor handle.
| Mon Aug 05, 2013 8:38 pm |
SwampDonkey1
Your clutch lever attaches over the handle coming off of the frame. You can take your cable that attaches the clutch lever to the throttle arm on the motor and zip tie the cable shroud directly to your handle. Allowing the cable to slide within the shroud and move your throttle arm. The shroud should also fit in a smaller bracket around the throttle arm on the motor to keep it under tension and from slipping and moving with the cable. This thread should answer alot of your questions... viewtopic.php?f=6&t=37586&p=452196&hilit=squeeze#p452196
| Mon Aug 05, 2013 11:03 pm |
[ 6 posts ] |
