It is currently Fri Apr 10, 2026 8:28 am
Reply to topic  [ 6 posts ]
 Throttle cable question
Post Throttle cable question
Got a duromax 16 xpe on a home build i am working on. Want to makr sure i have i have throttle hooked up right. Any one have one they can send me pics of how they run it.
Also how do you guys attache the cable to the handle.
Sun Aug 04, 2013 8:10 pm
Post Re: Throttle cable question
loosen the throttle arm and attach it through holes on the back of the arm (the bracket is sometimes hard to get to with the air cleaner and gas tank in the way). Might also need to get a spring to help act as a return. Run it to a clutch lever from one of those chinese ATV's, they can easily be ordered for $15 online.
1436 Lowe
Sun Aug 04, 2013 11:22 pm
Should of clarifed. Do you guys use cable tie to hold the cable in place what is best
Mon Aug 05, 2013 11:53 am
On Briggs motors theres a clamp that holds the Cable. I don't know what that motor has but it should have something. I dont think zip ties are going to hold.
Mon Aug 05, 2013 1:42 pm
I was thinking some thing like a guide i can screw into the motor handle.
Mon Aug 05, 2013 8:38 pm
Your clutch lever attaches over the handle coming off of the frame. You can take your cable that attaches the clutch lever to the throttle arm on the motor and zip tie the cable shroud directly to your handle. Allowing the cable to slide within the shroud and move your throttle arm. The shroud should also fit in a smaller bracket around the throttle arm on the motor to keep it under tension and from slipping and moving with the cable.
This thread should answer alot of your questions...
viewtopic.php?f=6&t=37586&p=452196&hilit=squeeze#p452196
1436 Lowe
Mon Aug 05, 2013 11:03 pm
