It is currently Thu Jul 03, 2025 7:53 pm
Reply to topic  [ 10 posts ]
 Anyone using an inverter?
Post Anyone using an inverter?
I have an idea that Im sure has been tried but I cant find any good info on it using the search feature on here or google. I want to rig my boat up to do some night fishing for crappie. I was trying to come up with an alternative to buying expensive, inefficient lighting made for crappie fishing. My thoughts are using a 12v deep cell battery, inverter, and Compact Fluorescent Bulbs. At around 13 watts per bulb I shouild be able to run 4 of these all night on one battery. Anyone tried it? Any luck?
Sun Jun 24, 2012 8:14 pm
Theirs people that use them,my cousin is giving me one to put on my boat. What about LEDs?
Sun Jun 24, 2012 8:21 pm
Post Re: Anyone using an inverter?
Inverters are horribly inefficient. Look at LED lighting. Very efficient and can run on 12v.
^^^ x2 on LED
http://www.fishinglightsetc.com/superbrite.html
Sun Jun 24, 2012 8:48 pm
Sun Jun 24, 2012 9:00 pm
I just did an experiment. I have a 140 watt inverter I picked up at walmart a while back to charge computers and what not in the truck, I hooked it up to my trolling battery and it drew .3 amps with nothing plugged into it, the fan was running on it. I plugged in a 13 watt fluorescent shop light and it drew 1.3 amps subtract the .3 and it is right on the money if you divide by the battery voltage. I then plugged in a 60 watt incandescent shop light and it drew 5.3 amps again subtract the .3 and it is still right on the money if you divide by the battery voltage. My thoughts before doing this is you would use the inverted 120vac as your divider but it looks as though you would still use the original dc voltage as your divider, which makes my idea about 10 times less efficient than I thought. Damn.
Sun Jun 24, 2012 9:14 pm
http://www.ledstrips8.com/
Just food for thought mounted under the rub rail
Sun Jun 24, 2012 9:42 pm
go over to bowfishing country forums, you can learn alot there. And you will probably be buying leds once you do the research
Sun Jun 24, 2012 10:23 pm
I do alot of crappie fishin and found that green lights work the best. Amazon has these led light strips for $30-$40. They work great and will run all night. You can add strips to make longer or jsut to double up your lights. They are in the underwater lighting section for aqauriums.
Excel 1851vF86 w/ MB 55V
SHIT HAPPENS
Mon Jun 25, 2012 12:01 am
customfitzled.com
You can get a 27w led and put any kind of tent to it.
send Chad and email and he might be able to get you exactly what you are looking for.
Wed Jun 27, 2012 3:45 pm
Users browsing this forum: No registered users and 40 guests
