It is currently Fri Jul 04, 2025 11:15 pm
Reply to topic  [ 11 posts ]
 trolling motor
Post trolling motor
i have a 1748cc Pro Drive hull and i want to put a trolling motor on it. Does anyone have a rig this size with a trolling motor? If so, what lb thrust? I don't want to go too small, but i also don't think i need the same size that's on my bay boat. Any input would be appreciated.
Sat Aug 04, 2012 6:35 am
Post trolling motor
I run a 40lb thrust on my 1842 that pulls my boat up to 3 mph. My friend has a 45lb thrust on a 1748 extremely heavy hull and it pulls it 2.5 mph.
Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here"
23GTR stage 2 by Calen pushin a 1746 Kliebert
Sat Aug 04, 2012 7:16 am
Post Re: trolling motor
What you gonna do with it? how many batteries you run? I say if you going with 12v then 55lb thrust. if 24v then 80lb. I've burnt up to many trolling motors. i have a 72lb on my 1442 jon, but then agian i bowfish in rivers. My brother had a 36lb on his 20ft pontoon and he was fine with it. guess its how much you want to spend. never seen where i would want to go small as possible.
Sat Aug 04, 2012 1:01 pm
Ran my Riptide 55 lbs. thrust on my brother's 18 x 60 PD X Series just fine. Practically could put that thing on a step!
Pulls my 18 x 54 Uncle J (MUCH heavier boat than the PD rig) very well. Mostly kept the boat in place in a pinch when I was stuck in 2' to 3' waves breaking over the bow in a stiff wind while trying to figure out what to do about my bent spud pole stuck in the spud holder! I finally had to fire up the PD to get out of that mess.
Sat Aug 04, 2012 1:10 pm
1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
Sat Aug 04, 2012 2:34 pm
i just put 55lb riptide on 1754 pro drive 12v and it yanks it all over the place
Sat Aug 04, 2012 6:46 pm
Had a 45lb 12V Edge on a 18x48 Geaux and now a 55lb Riptide 12V on a 20x60 Gatortail. Both worked just fine for trolling in the marsh, never killed a battery in a day fishing, although I never used them in situations where I was fighting heavy current.
1854 Gatortail CC . 35 GTR Stage 2
Tue Aug 07, 2012 6:17 pm
As stated above... it depends on your application. If you are fishing and can charge each day a 12 volt is plenty IMO. I have a Riptide 55 also and have been very pleased. Minn Kota is worth the $, again IMO.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Tue Aug 07, 2012 10:32 pm
Thanks everyone for the input. I ended up going with the Riptide 55 lb thrust.
Wed Aug 08, 2012 5:51 pm
Had a 55 lbs. riptide on mine that pulled the hell out of it. Great little motor. If you buy a minn kota, get the quick release bracket. Itll give ya the ability to pull a pin and take the whole thing off instead of unbolting it during duck season.
Wed Aug 08, 2012 5:57 pm
55lbs riptide all the way, got the one with ipilot on my 17x54 Uncle J, it will pull my boat 3mph or so going by the ipilot remote. Can run it 2 days fishing and still have half charge on my battery.
Uncle J 17x54
GTR 35
Fri Aug 10, 2012 9:43 pm
Users browsing this forum: No registered users and 51 guests
