It is currently Thu Jul 03, 2025 11:29 am
[ 8 posts ] |
fishingandwishing
Joined: Sun Aug 19, 2012 10:00 am Posts: 113 Location: Carencro louisiana
 Help with bowfishing rig
I have built some rails and want to order some LEDs. I want to know how many can I hook up to 1 deep cycle battery. I would like to use the same battery as my motor. I have a gtr the marine engine. I believe it has a 50 amp stator.
_________________ 35 efi gtr on a 17 x 54 extreme
Thu Mar 28, 2013 5:58 pm |
barnes_53
 Re: Help with bowfishing rig
but only 20 amps at 2k RPM or lower
Thu Mar 28, 2013 6:00 pm |
smokinfeathers
I would add a couple batteries n i could run more than what u will need
Thu Mar 28, 2013 6:19 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
Until you know what led's you want, we can't help you. The different sizes draw more or less amps per hour.
_________________ You have your whole life to be an idiot, take a day off!
Thu Mar 28, 2013 11:18 pm |
fishingandwishing
I would like to put the 50 watt seelite LEDs
Fri Mar 29, 2013 7:48 am |
Will
One 50 watt will draw 4.16 amps (50watts divided by 12 volts = amps) You could probably hook 4 (16.64 amps) to the same battery as the motor and won't have any issues. More than that and you'll have to run around to get the charging system higher to make up the difference. I'm not an expert but I think that's right...
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Fri Mar 29, 2013 8:33 am |
ChaseChapman
Joined: Wed Nov 28, 2012 6:41 am Posts: 79 Location: Louisiana
You are right but id be careful with that, if you leave your motor off for too long you might not have enough juice to start it lol. i would look into gettin a high ah battery, you can get a 100 ah for around 150 dependin on battery.
Tue Apr 02, 2013 5:37 pm |
Will
O yeah, note...do not leave lights on with motor off
Tue Apr 02, 2013 7:03 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 30 guests |
