cut'em94
Joined: Tue Oct 02, 2012 6:16 pm Posts: 291 Location: Luling, LA
 Generator Trouble
I have a generator for my bowfishing lights that is 3550 running watts. I have 7 500 watt lights, with 3 on chord, 3 on a chord, and 1 on a chord. Last time i went out, it kept shutting off and i kept having to reset the breaker. A couple minutes later it would do the same thing. Eventually it stopped, but this was the first time that it ever did this. Anyone have any ideas as to why this might have happened? I know 3500 watts is close to 3550, but I dont understand why it never did this before if thats the problem.
Tue Jun 24, 2014 7:13 pm |
msm8281
 Re: Generator Trouble
Use 6 lights
Tue Jun 24, 2014 7:20 pm |
cut'em94
Tried that for a while and it would still kill the generator. Ive got 2 on each side and 3 in the front so I dont want to take any off.
Tue Jun 24, 2014 7:22 pm |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
circuit breakers are going bad? Change a few out to 250's.
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
Tue Jun 24, 2014 7:24 pm |
cut'em94
Didn't think about that. Ill have to give it a try.
Tue Jun 24, 2014 7:31 pm |
BayouStateHunter
I run mostly 250's with a 500 up front. it works just fine but i'll make the led plunge hopefully soon.
Tue Jun 24, 2014 7:38 pm |
odass
With 7 50th your pulling 29 amps. That's too much when you factor the loss in to equation from the cords. You need to drop back to less. This is probably why 6 will still make it shut off. Probably weakened something
_________________ Dead Fowl Custom 1954hd with a GTR
Tue Jun 24, 2014 10:17 pm |
odass
Also I see you have 3 cords. Make sure your not pulling to many amps for plugs. The smaller generators usually have 15 or 20 amp plugs. Or one large 30 plug. Check that. Cuz even 6 would be to many amps on a 15amp
Wed Jun 25, 2014 7:21 am |
Quack Stackin
Joined: Mon Feb 14, 2011 6:07 pm Posts: 759 Location: NE ALABAMA
and what kinds of lights are they? some mh-hps lights require many more watts for startup than there running watts
Wed Jun 25, 2014 8:07 am |
cut'em94
I might try 4 cords to see if that helps. They are the $12 lights from Home Depot, cant remember the brand.
Wed Jun 25, 2014 11:46 am |
CaddoZ
Joined: Thu Nov 10, 2011 7:47 pm Posts: 236 Location: Caddo lake, Tx
If they are halogen lights, take out the 500 watt bulbs and put in 300 watt bulbs. Can't tell the difference and will give you 1400 watts to play with. Less strain on your generator too. And buy extras
Wed Jun 25, 2014 12:05 pm |
deltaduckmaster
Add twice as many lights and put 150 bulbs with a few 300 here and their  Sent from my iPhone using Tapatalk
Wed Jun 25, 2014 12:11 pm |
pearl river outlaw
Joined: Wed Jul 28, 2010 9:12 am Posts: 1407 Location: Louisville Ms
I run 8 300w halos and couldn't be happier on a 3500w genny and you also need to keep your genny pushing at less 80% of your max watts it will last you longer………
_________________ Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Wed Jun 25, 2014 12:47 pm |
deltaduckmaster
 Generator Trouble
You really aren't gonna notice the difference from a 500 to a 300.
Wed Jun 25, 2014 12:49 pm |
odass
Wed Jun 25, 2014 2:04 pm |
pearl river outlaw
Wed Jun 25, 2014 2:15 pm |
deltaduckmaster
Wed Jun 25, 2014 2:40 pm |
deltaduckmaster
I just changed out this light. Somehow got water in it and it went out. First light to ever have a bulb or any issue with in 700 hrs!!  Sent from my iPhone using Tapatalk
Wed Jun 25, 2014 2:44 pm |
cut'em94
Yea ill put some 300 bulbs in there instead. I shouldve gone with 10 250's or something like that. Ill know for next time.
Wed Jun 25, 2014 6:26 pm |
DUCK HEARSE
Joined: Fri Apr 06, 2012 8:48 am Posts: 3161 Location: Alabama
Just pay for a charter
_________________ Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
Wed Jun 25, 2014 6:29 pm |
cut'em94
Nah I've done pretty well with it so far. Already had the generator, bought the lights for $12 each, and already had the wood to make the stand for the lights. Most expensive thing was definitely the 2 bows.
Wed Jun 25, 2014 6:41 pm |
DUCK HEARSE
Add the cost of boat plus everything you should be eating lobster and steak
Wed Jun 25, 2014 6:44 pm |
cut'em94
Yea but i didnt buy the boat to bowfish out of, therefore it is a sunk cost. Im sure your just messing with me but you get my point.
Wed Jun 25, 2014 8:59 pm |
DUCK HEARSE
You are right it's not near as fun.
Thu Jun 26, 2014 6:44 pm |
SETx Longtail
DDM, I've got those same lights on my work truck... They will turn night into day, that's fo sho!!!! Mine obviously aren't tinted though.
_________________ #CFFITR
Thu Jun 26, 2014 9:16 pm |
jldsc
ive got the same too DDM..did yours come tinted or did you tint them? I put headlight tint on mine
Sat Jun 28, 2014 2:23 pm |
deltaduckmaster
I tinted them
Sat Jun 28, 2014 2:26 pm |
jldsc
I ended up putting 6 like that on a short light rail..seems to be reel good...havent got out to try em yet
Sun Jun 29, 2014 12:22 pm |
