It is currently Sun Jun 29, 2025 1:26 am
Reply to topic  [ 28 posts ]
 Generator Trouble
Post Generator Trouble
I have a generator for my bowfishing lights that is 3550 running watts. I have 7 500 watt lights, with 3 on chord, 3 on a chord, and 1 on a chord. Last time i went out, it kept shutting off and i kept having to reset the breaker. A couple minutes later it would do the same thing. Eventually it stopped, but this was the first time that it ever did this. Anyone have any ideas as to why this might have happened? I know 3500 watts is close to 3550, but I dont understand why it never did this before if thats the problem.
Tue Jun 24, 2014 7:13 pm
Post Re: Generator Trouble
Use 6 lights
Tue Jun 24, 2014 7:20 pm
Tried that for a while and it would still kill the generator. Ive got 2 on each side and 3 in the front so I dont want to take any off.
Tue Jun 24, 2014 7:22 pm
circuit breakers are going bad? Change a few out to 250's.
Tue Jun 24, 2014 7:24 pm
Didn't think about that. Ill have to give it a try.
Tue Jun 24, 2014 7:31 pm
I run mostly 250's with a 500 up front. it works just fine but i'll make the led plunge hopefully soon.
Tue Jun 24, 2014 7:38 pm
With 7 50th your pulling 29 amps. That's too much when you factor the loss in to equation from the cords. You need to drop back to less. This is probably why 6 will still make it shut off. Probably weakened something
Tue Jun 24, 2014 10:17 pm
Also I see you have 3 cords. Make sure your not pulling to many amps for plugs. The smaller generators usually have 15 or 20 amp plugs. Or one large 30 plug. Check that. Cuz even 6 would be to many amps on a 15amp
Wed Jun 25, 2014 7:21 am
and what kinds of lights are they? some mh-hps lights require many more watts for startup than there running watts
Wed Jun 25, 2014 8:07 am
I might try 4 cords to see if that helps. They are the $12 lights from Home Depot, cant remember the brand.
Wed Jun 25, 2014 11:46 am
If they are halogen lights, take out the 500 watt bulbs and put in 300 watt bulbs. Can't tell the difference and will give you 1400 watts to play with. Less strain on your generator too. And buy extras
Wed Jun 25, 2014 12:05 pm
Add twice as many lights and put 150 bulbs with a few 300 here and their ;)
17x48 extreme stage 2 GTR
Wed Jun 25, 2014 12:11 pm
I run 8 300w halos and couldn't be happier on a 3500w genny and you also need to keep your genny pushing at less 80% of your max watts it will last you longer………
Wed Jun 25, 2014 12:47 pm
You really aren't gonna notice the difference from a 500 to a 300.
Wed Jun 25, 2014 12:49 pm
Wed Jun 25, 2014 2:04 pm
Wed Jun 25, 2014 2:15 pm
Wed Jun 25, 2014 2:40 pm
I just changed out this light. Somehow got water in it and it went out. First light to ever have a bulb or any issue with in 700 hrs!! ;)
Wed Jun 25, 2014 2:44 pm
Yea ill put some 300 bulbs in there instead. I shouldve gone with 10 250's or something like that. Ill know for next time.
Wed Jun 25, 2014 6:26 pm
Just pay for a charter
- Mark Twain
Wed Jun 25, 2014 6:29 pm
Nah I've done pretty well with it so far. Already had the generator, bought the lights for $12 each, and already had the wood to make the stand for the lights. Most expensive thing was definitely the 2 bows.
Wed Jun 25, 2014 6:41 pm
Add the cost of boat plus everything you should be eating lobster and steak
- Mark Twain
Wed Jun 25, 2014 6:44 pm
Yea but i didnt buy the boat to bowfish out of, therefore it is a sunk cost. Im sure your just messing with me but you get my point.
Wed Jun 25, 2014 8:59 pm
You are right it's not near as fun.
- Mark Twain
Thu Jun 26, 2014 6:44 pm
DDM, I've got those same lights on my work truck... They will turn night into day, that's fo sho!!!! Mine obviously aren't tinted though.
-Custom pool noodle
-stage 4 water wings
Thu Jun 26, 2014 9:16 pm
ive got the same too DDM..did yours come tinted or did you tint them? I put headlight tint on mine
Sat Jun 28, 2014 2:23 pm
I tinted them
Sat Jun 28, 2014 2:26 pm
I ended up putting 6 like that on a short light rail..seems to be reel good...havent got out to try em yet
Sun Jun 29, 2014 12:22 pm
Users browsing this forum: No registered users and 57 guests
