It is currently Sat Jun 28, 2025 8:52 am
Reply to topic  [ 14 posts ]
 is my kill switch posed to be normally open?
Post is my kill switch posed to be normally open?
i hooked up a normally open kill sw and its workin bass-akwards...is it posed to be normally open or did i cross wires or sumtin'? i connected da wires tween the wires on da kill switch...wtf did i do wrong. when the button is pressed it turns da motor off. sad thing is i sell elec. supplies 4 a living! :roll: :lol:
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Thu Apr 29, 2010 8:04 am
MMT Moderator
Post Re: is my kill switch posed to be normally open?
GTB 1860 w/ 2019 GTR40XD-HO
Thu Apr 29, 2010 8:21 am
Thu Apr 29, 2010 8:45 am
MMT Moderator
Thu Apr 29, 2010 9:02 am
cajun call coco
Thu Apr 29, 2010 9:10 am
Thu Apr 29, 2010 9:42 am
It is suppose to be an N/C (meaning it is making contact), when the contact is broken then it will turn the motor off. You cannot hook up the wires backwards, because it is only 2 wires (doesn't have to be hooked up a curtain way). If your motor won’t start with the kill switch (plastic piece) in, then something is wrong. Either the kill switch or the wiring. If you have a meter you can check the kill switch, by putting the meter to read ohms (u) then touch the 2 wire post. If the meter reads something with the kill switch in place, remove the kill switch and put the meter across the 2 wire post, if you don’t get anything than the kill switch is good.
Thu Apr 29, 2010 1:25 pm
no such thing of a/c on a mud motor .....yet :shock:
Thu Apr 29, 2010 5:19 pm
Thu Apr 29, 2010 5:28 pm
Fri Apr 30, 2010 7:47 am
Starting to wonder why my mother always called me special.
1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust
premium oak reverse w/minnkota cruise control
Mon May 03, 2010 10:25 pm
i dont know exactly its just that how our silicone control RECTIFIERS on our rig works after the power is saturated by excitation from our D.C. EMD generators
Mon May 03, 2010 10:28 pm
and the excitation is from the exciter board before its reaches the ac module. but that would be cool for the motors to have a power inverter you could connect to your motor to have 120 vac like a generator. we def have the engine power to put out some serious current.
Mon May 03, 2010 10:32 pm
none of that was like a nerd rage at all more like blabbering on so dont hate on me not being a smart asz. after reading it again i think i ment to say converter i think. ok im done
Mon May 03, 2010 10:34 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 132 guests
