jeremyhit
 small transom tall transom
My boat has a 20in transom but the motor setup for 16in or smaller will that kill my mph or my holeshot or both thanks
| Fri May 14, 2010 6:09 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: small transom tall transom
| Fri May 14, 2010 7:22 pm |
jeremyhit
I have no idea first mudmotor and boat Dont know But thanks for the smart a$$ reply
| Fri May 14, 2010 7:35 pm |
dead animal
it will work but not nearly as good as it should. u got 2 choices
1. have ur transom cut down. won't cost too much and u could build it up again later if u need to.
2. have ur outdrive on ur motor swapped out to handle a tall transom.
i feel pretty sure u ain't gonna like how a short transom motor runs on a tall transom boat.
good luck with it.
| Fri May 14, 2010 7:39 pm |
jeremyhit
Does someone make a kit too change it over Its a godevil longtail
| Fri May 14, 2010 7:58 pm |
rebbeer
Joined: Thu Feb 05, 2009 7:39 pm Posts: 417 Location: Lafayette, LA
I had a friend that had the same scenario. First mudmotor either one of us ever owned. It ran fine and performed well, but it was hell keeping the prop in the water at full speed. That mf would wear you out trying to pick up on the handle the whole time running. We tried bending the tab up and it didn't help. It was a 27hp Honda go-devil. That thing was a beast in the mud.
_________________ 35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
| Fri May 14, 2010 8:01 pm |
cb5331
go devil. give them a call, they'll get you what you need.
jeremyhit
Thanks for the info and help Ill give godevil a call
| Fri May 14, 2010 8:09 pm |
bayouboy
| Sat May 15, 2010 7:42 pm |
M_coonass
itll just be hard as hell to hold in the water however much u bend the cavitation plate, itll still do the same thing.
_________________ 15x42 foot custom skiff, wit a 25 yamadog hangin on back of it. waitin on dat lt!
| Sat May 15, 2010 8:10 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
_________________ Put yer face in the myrtles.
| Sat May 15, 2010 10:08 pm |
bayouboy
| Sun May 16, 2010 3:34 am |
jeremyhit
Called godevil talked to warren and he had two ways to fix it Cut the transom down or cut the cavition plate off and buy a new one so I bought the plate He also said if it has a swivel base remove it and install a fixed base because it sets too high
| Mon May 17, 2010 3:26 pm |
caddobrook
I have no idea if this will work, but I am sure someone will point it out if it doesn't.
But have you thought of a jackplate? a manual one? just mount it low and then crank it down?
I know it works for the reverse problem....
Just not sure if the "kick back" or "kick up" whatever you would want to call it would then hit the transom-that would be the biggest concern..
Just a thought....
Or like they said, cut the transom down...
| Mon May 17, 2010 7:54 pm |
jeremyhit
Just getting ready to weld my new cavitation plate on and was wondering how close should it be from the top of the prop and its a new prop
| Thu May 20, 2010 5:37 pm |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
good luck.. sounds like your gettin ready to cause more problems than you had. but hey, its yours, not mine
_________________ Sometimes it's best to just keep your fingers quiet...
| Fri May 21, 2010 7:02 am |
