It is currently Sat Jun 28, 2025 9:27 pm
Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
 Mud Buddy 6000 hd + iron mtn heads
Post Re: Mud Buddy 6000 hd + iron mtn heads
Good to hear EVT fixed you up.
Sat May 22, 2010 9:56 pm
you must of been the guy with the IMs that Robert was recently reworking.... when did you pick up your boat? I hope to get my Generac on my boat later this week... did you pick up your boat at Roberts house or at the shop? Reason I am asking is if you were at Roberts house you probably saw my airboat...
Sat May 22, 2010 9:59 pm
ya i got it this morning, he showed me you AB and what he was going to do to it. i went to his house/shop and saw it. Its looks Bad A.
JR
JReese
1754 GatorTrax w/ MB 6000 customized by EVT
Sat May 22, 2010 10:02 pm
toys.... gotta love 'em
Sat May 22, 2010 10:13 pm
Fish_hook I dropped my 23mini off a week ago and saw your boat. He told me about it, the problems etc. Glad you got runnin great, they are some great guys to deal with. I cant wait till he gets into mine. Saw your airboat to brlcla, looks like a beast.
Sun May 23, 2010 12:28 pm
ready to get it back.... are you getting your 23 mini bored out? Robert said he had a 23 that was going to the machine shop with my 33 Generac
Sun May 23, 2010 1:09 pm
Im gettin stage 1 headwork, mikuni carb, modded stock muffler and a couple 35 parts here and there I believe. I kinda set him free on it, gave him a price limit and said do what you think. Just beefin it up. I dropped it off on the 16th. Cant wait to get it back and see what it does!
Sun May 23, 2010 6:32 pm
Glad you are running well now fishhook. The guys at EVT have always done me right.
Sun May 23, 2010 6:40 pm
If I wanted 60hp I would not beef up a Briggs engine but rather spend all that hard earned money on a balanced 88 to 96 cubic inch harley or balanced S&S V-twin to get some smooth reliable power to that prop. I know you're already into this project deep so ignore my suggestion (I just couldn't help myself). I hope you get it figured out soon.
Wed May 26, 2010 7:03 pm
Air flow.... the biggest issue with harley or s&s motors on these engines is cooling.... getting the air flow across the cylinders... you would have to add external electric fans...
it can be done and has been done.... still a lot of testing to do before they become mainstream... also have to look at power to weight ratio.... if i can get reliable 60 HP from a 165# motor why would i spend $$$$ on a harley that weights over 200#...
Wed May 26, 2010 7:28 pm
I must concur that if you can get 60 reliable HP from a briggs then that would be another story. Run the harley and S&S a little rich and install a couple quality oil coolers and don't get too crazy on the timing would give you a starting point not too mention possibly needing a larger prop and a different gear ratio with a beefier belt. If I had the money I'd be all over this type of experiement along with welding up a chrome moly frame for weight reduction. Slap something like that on an 18x60 or 20x60 hull to support the added weight of the motor and things could get interesting.
Wed May 26, 2010 7:42 pm
I think you can easily get 60 reliable HP from a Briggs.... there are plenty of them out there... i think you can get 70HP reliably from a Generac....
Just because you read about 1 out of 10 modded motors having issues doesn't mean they are not reliable.... I truthfully think that Briggs does not go through all the tolerancing that Harley and S&S go through which leads to noticeable differences in these engines.... come on they are industrial equipment that are designed to be beat to death... you can't tolerance them to well.... that is where a lot of the effciency is lost...
Lots of differences between the way Briggs and Generacs are made vs Harley and the highe end bikes.... actually lots of differences b/w briggs and generacs themselves....
if these motors were not reliable i don't think the builders that do the work could be keeping a good business going from them...
actually the failure rate is much less than that... if you start digging...
but these are just my opinions from what i have read and experienced...
Wed May 26, 2010 7:51 pm
Sat May 29, 2010 12:59 pm
What jets are you running in it? Main and pilot jet?
James E Abell
Gatortrax 3man Hide
MB 7000 & 32"
Mon Jun 07, 2010 8:24 pm
Users browsing this forum: No registered users and 155 guests
cron
