It is currently Sun Jun 22, 2025 9:34 am
[ 8 posts ] |
deaddrake
 bent up skeg
my skeg has taken a beating from rocks and stumps, the bottoms is kinda mushroomed. should i grind this back smooth or what cause im sure its causing my motor to pull to the side. need some advice from someone in the know. and also can i bend my handle without making it weak.
Tue May 11, 2010 5:52 pm |
Pintail58
Joined: Fri Feb 06, 2009 8:17 am Posts: 578 Location: Lafayette , La on da outside
 Re: bent up skeg
I'de grinde it back down it the metal is still good. As far as the handle if you use a tubing bender it will work better than just trying to bend it b/c by just trying to bend it you risk creasing it.
_________________ Shoot 1st ask later 14' leaker w/ 20hplt Shootin time Teal Season 2010 http://xrl.in/64aw #countdown
Wed May 12, 2010 7:18 am |
balloon-knot
Joined: Wed Jan 14, 2009 9:05 am Posts: 398 Location: Prairie du Chien, WI
 Re: bent up skeg
If you take too much off with the grinder you will get more prop hits.
_________________ Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Wed May 12, 2010 2:54 pm |
deaddrake
 Re: bent up skeg
is there a way to add on to it. like a bolt on skeg to replace a worn out one.
Wed May 12, 2010 5:42 pm |
Pintail58
 Re: bent up skeg
Welding Machine
Thu May 13, 2010 10:03 am |
deaddrake
 Re: bent up skeg
yeah im actualy gonna take it to a local welder and see if he can weld me an extension so to speak on my existing skeg. i can run the heck out of my go devil, but as you can tell i know nothin about em except running em. mine is just now starting to need work so bare with me, im still learning about working on em.
Thu May 13, 2010 4:32 pm |
dead duk
Joined: Thu Jun 25, 2009 10:45 am Posts: 147 Location: Longview,Texas
 Re: bent up skeg
I had the same problem. I have a 27 horse MB and the skegs on them are flimsy in my opinion. At first I used a large crescent wrench to bend the skeg back into place. It worked ok, but I was concerned the metal was weakened and would eventually start to bend back from hitting stuff. I made a template of the skeg and found some 14 ga. flat stock. I traced the outline of the skeg and cut out the shape from the flat stock. I drilled holes throughout the flat stock. I then welded the stock onto the skeg along the edges and then filled in the holes. The welding process sucked the skeg back to being straight. I am not a professional welder by any stretch of the imagination, but I am learning. I feel the project turned out well. So, if you have any welding abilities, it will probably turn out better than mine. Good Luck.
Mon May 17, 2010 6:30 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
 Re: bent up skeg
i had the same problem. i took 3/8 stainless round stock cut a 1/8 inch groove down it and welded it up the length of the skeg. stainless can take a beatin'.
Wed Jun 09, 2010 6:38 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 64 guests |
