It is currently Sat Jun 28, 2025 2:25 am
Reply to topic  [ 22 posts ]
 New Shaft Mounted Roller Rockers Arms for 35’s
Post New Shaft Mounted Roller Rockers Arms for 35’s
We are excited to announce the release of our new Shaft Mounted Roller Rocker Arm System for 35 HP Briggs Vanguard engines. This new rocker system is fabricated from 7075 T6 aluminum in house and features a hardened tool steel shaft rod, high quality American made needle bearings and Comp Cams rollers to contact the valve surface. Extensive testing has went into this new system and the design is very unique to other systems as you will see from the picture. Our new system will put a tremendous amount of stability in your valve train system when compared to all other rockers do to the design and the shaft mounting pedestal. There is a tremendous amount of support for the entire valve train with this design. Regardless of the amount of horsepower your engine is making this innovative new system will increase power and live for a long time.
With our new system, machining is not necessary. Just mount them, set your valve lash and go! Our new Shaft Mounted Roller Rocker Arms Systems are in stock and ready for shipment.
Thanks,
Gecker Motorsports Products
Tue Mar 02, 2010 4:39 pm
Post Re: New Shaft Mounted Roller Rockers Arms for 35’s
How about price. And can we see them mounted on a set of heads.
Chris
Tue Mar 02, 2010 4:56 pm
What ratio are they?
Tue Mar 02, 2010 5:27 pm
You state that no machining is required...how do you mount them without shaving down the boss on each rocker arm pedistal?
1848 Brother w/ 36 PD
Tue Mar 02, 2010 8:29 pm
send me a set to try!
Tue Mar 02, 2010 8:30 pm
Tue Mar 02, 2010 8:42 pm
Not understanding how those mount up by that one pic. We need more onfo.
BUCK OFAMA
Tue Mar 02, 2010 9:36 pm
Do you use threaded steel inserts for the adjustment screws to mount in? I have not had a lot of luck with steel and aluminum threads against each other.
Mark F. Cheney
on the Great Salt Lake marsh
Wed Mar 03, 2010 9:05 am
This system slides down over the existing pedestal mounts on the head and bolts hold it to where the stock rocker arm studs used to be. It does not require a valve cover spacer or clearancing to the head. They are super slick pieces.
We will upload one more photo as it sits on the head soon.
We have a special preliminary price of $285 plus freight.
Wed Mar 03, 2010 12:35 pm
Attached is a picture of the system sitting on a cylinder head.
Thanks
Wed Mar 03, 2010 4:45 pm
Again.....what is the ratio?
Wed Mar 03, 2010 4:47 pm
u'r valve is in de wrong place!
Wed Mar 03, 2010 4:48 pm
She stuck it in there to take the photo!
The ratio is .05 more than stock.
Thanks
Wed Mar 03, 2010 4:57 pm
How about that pic?
Wed Mar 03, 2010 4:59 pm
ETD88 09/28/09-05/14/2010...
Wed Mar 03, 2010 5:00 pm
Me too...
Here it is again for your viewing pleasure::
Wed Mar 03, 2010 5:01 pm
By the way, the used intake valve is no included.
Wed Mar 03, 2010 5:02 pm
Wow that was great! :lol:
BUCK OFAMA
Wed Mar 03, 2010 8:29 pm
Sat Jun 12, 2010 5:16 am
Sat Jun 12, 2010 7:13 am
i'll just go ahead and take everyone's advice and stick with what i got :D
"I have been blessed with many things in this life, an arm like a rocket, a c*ck like a Burmese Python and a mind of a f*ckin scientist."
-Kenny F*ckin Powers
Gator Trax 3-Man Gatorhide with a Mud Buddy HD Sport 5000
Large Big Green Egg with rounded chines
Sat Jun 12, 2010 7:49 am
Users browsing this forum: Google [Bot] and 93 guests
