It is currently Fri Mar 27, 2026 10:45 pm
Reply to topic  [ 4 posts ]
 trim tabs
Post trim tabs
Has anybody ever run trim tabs with a LT I have been lookin at the smart tabs from nautalis. Running a 23 gd on a 15-42 war eagle. trying to get it to plane a little better under load. I dont really want to spend the cash on pods.
1542 war eagle 23 gator
Mon Aug 02, 2010 11:24 am
Post Re: trim tabs
yes, got a 24hp on a 1448 tracker. with trim tabs. work good for me. also will help with shallow water runin. trim them down and it funnel the water up higher to prop. my what to try moving weight to front.
Mon Aug 02, 2010 7:36 pm
Post Re: trim tabs
What kind of tabs you runnin I liked those nautalis ones cause the would be adjustment free. I got the weight balanced in the boat pretty decent. Just try to get a little more out of it. I would like to get pods but with the back of the boat not being flat across. Every welder/fabricator I have talked to. thinks there skills are worth way more then I want to spend.
Tue Aug 03, 2010 7:40 am
Post Re: trim tabs
i have lenco tabs with a switch on my handle. so i can adj. up or down . with ele. tabs if u need to push boat back up can trim up. my tabs are on one switch and they stay in time with each other. as long they are time from install. ele. tabs are about 320.00 for pair. pod from beavertail at www.explorebeavertail.com for small pods are 389.00. but u can either bolt them on or weld. hope this helps.
Tue Aug 03, 2010 7:22 pm
cron
