It is currently Fri Jul 18, 2025 12:10 am
Reply to topic  [ 22 posts ]
 Need a lil advice
Post Need a lil advice
Gettin me a boat fabricated and need to know a few specs on a trailer. I am gettin a 18x48 boat. I have ordered my axle and all the trailer hardware. I got a 3500# axle and 14" tires. I know it is a lil overkill but the price wasn't that much difference. I will probably built it out of 2x3 tubing. I build grills/smokers on trailers so I know how they go together and I know axle placement on a utility trailer. My question is do any of you guys have any specs on how long it needs to be and axle placement? If i had the boat here it would not be that big'a deal. Thanks
Tue Aug 10, 2010 7:38 pm
Post Re: Need a lil advice
i just went outside and measured my dads 18.. its roughly 5 ft from the back of his boat / trailer to the center of the axle..
my 19 ft was right at 5.5 ft.
utility trailer is divide open floor by 1/2, then add an inch for every foot. that is where center of axle goes..
therefore a 18' trailer / half = 9 ft.. 18 ft = 18 inches.. so center would be 10.5 ft from front.
start your break/ wrap tongue at 3' from front.
i know u said u buidlin a boat trailer, but i would presume the breaking point for the wrap tongue would be the same. i want to say the formula for a boat trailer is 3/4 the length of the boat?
Tue Aug 10, 2010 10:01 pm
Profile YIM WWW
Take the length of the boat divided by 2 then subtract 2 ft . That will give you the measurement from the rear of the trailer for your axle placement. So a 18ft boat would approximately be 7ft form rear of trailer. Which gives you ample enough tongue weight ,but not too much that you can't pick it up..
Or you could weld the axle hangers to some angle iron that you would U-bolt to the trailer frame and it could be permanantly adjustable. Which is what we call a sliding axle. hope this helps.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Wed Aug 11, 2010 3:49 am
Thanks guys. I have always did the inch per foot backspace on the utility trailers. I wasnt sure about the boat trailer. I just want to make sure that the boat is not hangin off the trailer a foot or two when I get it done. I also wasnt sure when to start the taper to the tongue up front. Jus10 is that the 3' you talkin about? Thanks
Wed Aug 11, 2010 7:08 am
Tell me more about the vessel you are having constructed..
Wed Aug 11, 2010 8:26 am
yep u got it. 3' behind the NOSE of the boat is where u start your bend at.
Wed Aug 11, 2010 11:32 am
Profile YIM WWW
Wed Aug 11, 2010 11:56 am
Sometimes it's best to just keep your fingers quiet...
Wed Aug 11, 2010 11:58 am
he must be talkin bout Brother Breaux
allow yourself roughly 4 ft of tongue in front of the nose of your boat. when u make the bend in your wrap, the channel should fall out roughly 18 inches behind the coupler. that is assuming your going with a 3" square tube center, 4" channel frame, and 2x3 cross braces.. reason i always used 4" frame tied into the 3" tubing is so it will overlap the tubing and have a more solid, factory looking weld.
Wed Aug 11, 2010 12:12 pm
Profile YIM WWW
Torsion axle!!!! Love em!
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Wed Aug 11, 2010 12:19 pm
:cry:
Wed Aug 11, 2010 12:39 pm
Put yer face in the myrtles.
Wed Aug 11, 2010 5:35 pm
Will this pic help
18x48 GDSD boat
Wed Aug 11, 2010 6:10 pm
Randy that your rig? Damn nice. U can put sum fish in there!!
Wed Aug 11, 2010 6:14 pm
Profile YIM WWW
Wed Aug 11, 2010 6:30 pm
I think you need to add another axle..... :shock:
1854 Brother pulling a 36 PD
viewtopic.php?f=5&t=12825
Wed Aug 11, 2010 7:49 pm
lol those cats that run the locks down here shad dippin all got double and triple axle trailers. they put sum weight in them bitches...
Wed Aug 11, 2010 8:34 pm
Profile YIM WWW
Thanks, Jus10 I am thinking about building the complete trailer out of 2x3. Is that a bad idea?
Wed Aug 11, 2010 9:22 pm
Channel will not bow as bad as angle.. If ur gona custom build ur trailer,, dont try to cut corners do it rite the first time. May be a lil more money but its worth it in the end
Whos buildin ur boat? If its brother.. Get with him about helping u with a trailer. He also builds trailers..
Wed Aug 11, 2010 9:59 pm
Profile YIM WWW
I got 2x3 tube to build it out of, not angle. I forget the guys name who is gonna build it, I hear he is bipolar and I aint sure what he goes by.......today :lol:
Thu Aug 12, 2010 7:52 am
Thu Aug 12, 2010 11:38 am
Profile YIM WWW
what happened to 70/30 for single axle and setting the center of the tandems are the 70/30? Sounds like yall making it to complicated to divide by half, add 1" per foot, yadda yadda yadda.
Thu Aug 12, 2010 2:54 pm
Users browsing this forum: No registered users and 107 guests
