benny365
Joined: Fri Feb 26, 2010 11:04 am Posts: 35 Location: Onalaska, Wi
 how much and with what?
How much are valves shimmed and with what, is there something to buy or do you make your own.
I have a 35 gdsd and I wouldn't mind a little valve float protection.
thanks
Thu Aug 12, 2010 9:27 pm |
MaXXis85
 Re: how much and with what?
Do you have mods that allow your engine to rev 4350+ RPM with the prop engaged running in the water? If not dont bother.
Fri Aug 13, 2010 6:35 am |
benny365
no mods, but I do run 4200 rpms in the water, If I hit something and the prop comes out of the water. might turn more than 4350
Fri Aug 13, 2010 6:03 pm |
cb5331
not unless you disconnected the gov, you won't. Also, how old is your prop. Is it a cdi motor? 4200 seems a tad bit high for a stock motor and prop.
Fri Aug 13, 2010 6:06 pm |
Shadow
Joined: Tue Mar 30, 2010 7:11 pm Posts: 798 Location: Shreveport, LA
My motor doesn't have docking assistance, it has REVERSE!
Fri Aug 13, 2010 6:24 pm |
deadbird8
Could be a hot motor, my old one ran 4380 with just an exhaust.
Then again, he could have an e-fuel pump
Fri Aug 13, 2010 6:25 pm |
cb5331
Fri Aug 13, 2010 6:35 pm |
benny365
Hot! not sure about that. no fuel pump either. I get about 27 to 28 mph at 4150 to 4200 rpm. I just worry about overreving it if I would hit a stump or something. motor only has 20 hrs and prop is like new.
Fri Aug 13, 2010 7:23 pm |
Shadow
Fri Aug 13, 2010 7:24 pm |
cb5331
If your running 4200 with a good prop on a stock motor, I'd say you've got yourself a hot one. Thats a good thing. Your motor has a governor on it that does not allow it to over rev. You have nothing to worry bout. Just go run that biatch. Oh, and the fuel pump thing is a joke. I don't know what crawled up ol DB8's ass, but he's having a lot of fun with it.  I do run one, but I'm silly like all the rest of them. It's not needed... If it is thought to be needed, you have other problems.
Fri Aug 13, 2010 7:28 pm |
benny365
Fri Aug 13, 2010 7:36 pm |
