It is currently Wed Jul 01, 2026 4:00 pm
Reply to topic  [ 27 posts ]
 16X54 Legendcraft Stage III EVT 36 hp pd
Post 16X54 Legendcraft Stage III EVT 36 hp pd
just got my rig together...
me
friend
dog
6 gallons of gas
29mph
Tue Aug 17, 2010 12:32 pm
Post Re: 16X54 Legendcraft Stage III EVT 36 hp pd
how heavy is the boat
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Tue Aug 17, 2010 12:34 pm
My rig will run 30 with two guys and its only got a stage 1. Somethin aint right with the boat.
Tue Aug 17, 2010 12:55 pm
That was my point in asking the weight of the boat
I run a stock 36PD on a 20x48 and get 27 with the same weight
Something is wrong I would guess he should be getting a good bit more mph out of it.
Aucoin 20X48 36pd
Tue Aug 17, 2010 2:20 pm
The legendcrafts are a lil heavy. A lot of them built with horizontal bracing, not lengthways. They hook pretty bad. May have a wood floor? Waterlogged flotation?
We have a 1648 lc that had a hard time floating a 32 pd. I would think the added width would help with that, but could still have a similar issue. If the hull is hooked all to hell, and the ass is dragging like no other, your gonna lose some speed.
He did say he just got it together. Maybe he hasn't run it much. Need to play with the trim, possibly props, and weight distribution.
Good luck man, and congrats on the new rig. 30 mph is still good speed for a mud boat, so don't let it get you down. I'm guessing you got a few mph hidden somewhere...
Tue Aug 17, 2010 2:26 pm
the hull was purchased used, and has some hooks, and the motor is used too, was a smokin deal for the motor. Im new to the mud motor so im trying to figure out the operation completely.. where should i trim it when trolling/slow speeds, and where is the sweet spot during full speed?
hoping to get the speeds up..but overall im pleased with the boat... its fun to get back in the shallow water and vegetation!
Tue Aug 17, 2010 2:43 pm
You should beable to run 30MPH with a Stage 3 on a bathtub.. Something defently aint right. Unless you got some really bad Hooks...
Uncle J
Tue Aug 17, 2010 2:45 pm
You have to play with it, every hull is a lil different. To get the trim right when running wide open, slowly trim it up until you start to lose speed, then trim it back down a tad. Once you get going and up on plane, just bump the trim up and down until you find it. Most of us just set it close to the "sweet spot" as possible and leave it there for idling around and what not. Depending on your load, you may have to move it around a lil bit, but should not take too much.
Another thing is, weight distribution is a huge factor. You will have to play with this a lot, but in my boat, it seems to run best with most of the weight directly over the center of the boat. My dad's boat runs a lil better with most of the weight just to the rear of center. I slid a cooler about six inches to the center while running one day and picked up 2 mph. Just have to play with it and use a gps. Once you kinda get a feel for how she runs in each particular situation, you won't need to focus so much on the gps.
Tue Aug 17, 2010 2:53 pm
Every boat is a little diffrent. I run mine where it has the least tiller torque. you should not have to trim the motor once you find the sweet spot. run the same trim at idel and WTFO. Only time I mess mith my trim is when I stop in some deep mud and then I trim down to get it moving then trim back up to the sweet spot. Now this will all change with diffrent loads. Try and start by triming the motor level when the boat is sitting still then just bump it up a hair. This is usualy get you close enough.
Aucoin 20X48 36pd
Tue Aug 17, 2010 2:56 pm
I push a 1854mvsld Seaark 30 mph, am thinking about going to the smaller boat for more speed but would like to see some results first I guess.
Tue Aug 17, 2010 11:57 pm
thanks for the advice fellas!
Fri Aug 20, 2010 9:51 am
took it out this weekend..three guys, 12 gallons of gas, and we got up to 27..
Mon Aug 30, 2010 3:20 pm
Mon Aug 30, 2010 3:23 pm
I run that with a 36pd on a 20x48 bone stock
Aucoin 20X48 36pd
Mon Aug 30, 2010 3:26 pm
Mon Aug 30, 2010 4:39 pm
To be successful, you must decide exactly what you want to accomplish, then resolve to pay the price to get it.
Mon Aug 30, 2010 4:42 pm
:lol:
Mon Aug 30, 2010 4:43 pm
Mon Aug 30, 2010 5:03 pm
Mon Aug 30, 2010 5:17 pm
get some videos on here with showing the load with how many people in your boat and a gps! That is the best proof out there.
Mon Aug 30, 2010 6:51 pm
Tue Aug 31, 2010 11:16 am
Aucoin 20X48 36pd
Tue Aug 31, 2010 11:47 am
Sun Sep 26, 2010 1:26 am
Sun Sep 26, 2010 7:04 pm
18x60 GTB
35 GTRrrrr
Sun Sep 26, 2010 8:25 pm
i'm sick, i got a brand new 35gtr on a 48"x20' an only get 24mph.What could i do to speed up without voiding my warranty. theres nothing in the boat,its like a tub with a motor on it.
Sun Sep 26, 2010 8:44 pm
Mon Sep 27, 2010 12:34 pm
