It is currently Mon Jun 30, 2025 1:47 am
Reply to topic  [ 14 posts ]
 ??? 25 kohler ???
Post ??? 25 kohler ???
well i got a question. my kohler starts 2 make a ticking sound after i run it awhile, it dont lose any power just bothers me. Is it the lifters, bent push rods, or what . thank u 4 the help
Prodigy 1851 elite timber , 4400 HDR .
Mon Sep 13, 2010 6:57 am
Post Re: ??? 25 kohler ???
Ticking from the valve cover area? How many hours on the engine? Might need a valve adjustment.
Mon Sep 13, 2010 8:32 am
yea it sounds like it is around the exhaust. It is my buddys motor. But like he said when the motor gets warm it has a slight tick. Aint sure if it is an exhaust leak or valves
Mon Sep 13, 2010 9:12 am
If its an exhaust leak youll see a little BLACK CARBON near the gaskets.
Mon Sep 13, 2010 9:14 am
The kohlers should not need valve adjustments. You can pop the valve cover off and have a look if you want. Unless you know how to set the valves with hydraulic lifters, I would take it to someone who does before you start jackin with it.
Mon Sep 13, 2010 9:20 am
I aint sure what it is, it dont lose power but has the lil tick after it gets warm but I dunno. Thanks for the tips
Mon Sep 13, 2010 9:23 am
Sounds like an exhaust leak to me....
Might be something where when it warms up, a leak opens up a little more....
Depending on what exhaust it has, could be on the exhaust itself, could be the gasket, or could be at the flange...
Mon Sep 13, 2010 9:40 am
its all just stock exhaust and its a 99' model
Mon Sep 13, 2010 9:49 am
11 yr old exhaust.....
Without hearing it myself and based on what you describe and assuming you have sufficient oil in it, I stick with my original thought that it is an exhaust leak (pinhole).... That will make a ticking sound sound...
Mon Sep 13, 2010 9:58 am
thanks man
Mon Sep 13, 2010 10:01 am
just got off wok thanks 4 the help gona order a exhaust . got gaskets own the way. what you guys suggest own after market exhaust?
Mon Sep 13, 2010 2:29 pm
You have two options on the kohler...EVT or BPS. I run the evt and am happy with it, very nice sound to it. Have not seen or heard the bps for the kohler so I won't comment on it.
Mon Sep 13, 2010 10:03 pm
mine did that once. You might think I'm crazy but change the oil then see if it goes away.
Tue Sep 14, 2010 7:26 pm
friends of mine's knocked/tapped bad
took the valve covers off....all four of the valve push rods were bent or bowed!
Tue Sep 14, 2010 7:54 pm
Users browsing this forum: No registered users and 104 guests
