It is currently Mon Jun 30, 2025 2:21 am
Reply to topic  [ 7 posts ]
 gtr 35 fuel/carb issue
Post gtr 35 fuel/carb issue
Ok,when i pump the bulb, i am getting fuel out of the line that comes out of the fuel pump, but when i connect it to the carb, i get nothing comming out of the carb unless i pump the bulb REALLY hard....any suggestions on the fix for this? motor will start when fuel is dumped into carb
also my choke cable broke, any cheap fixes?
Fri Sep 17, 2010 10:46 am
Post Re: gtr 35 fuel/carb issue
DO NOT PUMP THE BULB REALLY HARD.....YOU WILL RUPTURE THE DIAPHRAM IN THE FUEL PUMP!!!!! Only pump your bulb until you see fuel move into the fuel filter!!
Fri Sep 17, 2010 10:50 am
ok so what is my problem and how do i fix it?
Fri Sep 17, 2010 10:52 am
Does the motor run?
Fri Sep 17, 2010 11:19 am
only if i put gas down the carb
Fri Sep 17, 2010 11:44 am
Look on the bottom backside of your carb and see if your carb. is equipped with an electronic fuel shutoff solenoid.
Fri Sep 17, 2010 11:50 am
If you have the anti-backfire solenoid on the carb bowl, you should hear a 'click' when you turn the key on.
You can disconnect your fuel tank and run a line with filter and primer bulb from a fuel can at the transom and see if it runs while you use the primer and manually pump. If so, your problem is on the supply side somewhere.
Sun Sep 19, 2010 4:35 am
Users browsing this forum: No registered users and 97 guests
