It is currently Sun Jun 29, 2025 9:55 pm
Reply to topic  [ 9 posts ]
 tachometer question
Post tachometer question
im looking to install a regular marine tach on my 25 gdlt, and was told that i could use the kill switch wire that goes to the coils as a signal wire, does that sound correct to you guys?
Wed Sep 22, 2010 3:28 pm
Post Re: tachometer question
bump
Thu Sep 23, 2010 11:34 am
Does it not just wrap around the spark plug wire? It actually has to be tapped in to a wire?
Thu Sep 23, 2010 11:47 am
yeah the tiny tach ones do, i would like to install a boat tach with a backlight, similar to what goes in a car.
Thu Sep 23, 2010 12:03 pm
Does it not get the signal the same way? Post up a wiring diagram or a link to one...
Thu Sep 23, 2010 12:04 pm
well, car tachs use a signal from the coil to determine rpm, and im not sure if the coil wire on my kohler does the same. i know it has voltage to the wire going to the lanyard cuz it always shocks the shit outta me
Thu Sep 23, 2010 12:06 pm
:lol: I think a lot of the "marine" tachs, especially one's for outboards work similar to the tiny tach. But if you have a volt meter, set it to ac and see what that wire your talking about reads. If it fluctuates when rpm's change, I'd think it would work. Hopefully the tach has some different settings so you can get it tuned to read whatever voltage the kohler uses.
brlcla posted up one a while back that is backlit and works like the tiny tach. It would work for sure. Same company makes one for oil temp that I've been looking into...
Thu Sep 23, 2010 12:15 pm
cool, what brand?
Thu Sep 23, 2010 12:16 pm
Dakota? You can search my post for it if you want, or br's post's. Its up on the board several times.
Thu Sep 23, 2010 12:20 pm
Users browsing this forum: No registered users and 130 guests
