dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Trim relays craped out again!!! 2010 GTR23
Never fails... Just humidity in my battery box after a rain craps out the trim relays. I can hear them clicking when I engage the trim switch but no trim happening. Does any one have a permanent solution this problem? Don't tell me to install tiller control, I know about that already. I've tried everything...silicon seal, rubberized tape, ziplock bag but it seems just takes the slightest moisture to short the relays.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Thu Sep 23, 2010 10:01 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: Trim relays craped out again!!! 2010 GTR23
If you already know about the tiller control, then....what you waiting on?
I dunno if you are gonna be able stop the moisture, and it seems that when something like that starts, it's hard to make it stop.
_________________ Put yer face in the myrtles.
Thu Sep 23, 2010 10:09 pm |
MaXXis85
make sure you fold the excess wires in your battery box, so that the relays are on the top of the box. Drill a hole in the bottom of the battery box so water can drain through. Other than that,maybe put some dielectric grease on the poles to keep from corrosion. But the tiller box will rid all of your problems.
Fri Sep 24, 2010 6:27 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Fri Sep 24, 2010 6:33 am |
Gigafowl
Trim control on the tiller - innovation ?
Is there an OnStar call button too ? Hello - Hello is anyone there - Lol
But seriously - if it is so new that he didn't get it on a 2010 model - how do you know the long term benefits ?
Fri Sep 24, 2010 6:48 am |
dguidry
Fri Sep 24, 2010 7:05 am |
craig
Fri Sep 24, 2010 7:08 am |
MaXXis85
Knock on wood i havent had an issue with my Relays. Same ones from 2008. I always kept them high in the box and I havent had an issue. Slambin had an issue with his once because his relay happend to work its way low in the box and get some salt water in the box and that took out the relay. Changed it and he was back in busines..
You can pout dielectric grease on the teminials, plug it in and electrical tape the hell out of it to make a tight waterproof seal and hope for the best.
Fri Sep 24, 2010 8:03 am |
