It is currently Mon Jun 30, 2025 1:06 am
[ 7 posts ] |
broz
Joined: Tue Jan 13, 2009 6:24 pm Posts: 199 Location: Dayton, TX
 35 gtr idle issue
My 35 gtr idles around 1200 but when I put it in gear the rpm's steadily drop down To 500 and falling till it dies if I don't throttle it. All I know to do is adjust the idle screw (screw that stops the linkage?). But I don't want to increase the rpm's any higher in neutral. I know the stock carbs don't idle the best but if I can fix the problem it would be nice. Any suggestions.
Mon Oct 25, 2010 9:24 am |
quackconsumer
 Re: 35 gtr idle issue
Behind your motor der are 2 spring one goes to an arm wit 3 holes in it to hook da spring to and another smaller spring above it dat attatches to a tab, bend dis tab out away from da engine slightly. Dis will keep your RPS's from falling whenever a load is put on da engine, like engauging da clutch.
Mon Oct 25, 2010 9:46 am |
WestEndAngler
MMT Moderator
There use to be a diagram that illustrated what you needed to do. Anyone have that?
Mon Oct 25, 2010 10:07 am |
quackconsumer
Mon Oct 25, 2010 10:11 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
Mon Oct 25, 2010 2:35 pm |
quackconsumer
Mon Oct 25, 2010 3:00 pm |
quackconsumer
Mon Oct 25, 2010 6:38 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 82 guests |
