It is currently Sun Mar 29, 2026 8:40 pm
Reply to topic  [ 25 posts ]
 27 kohler Beavertail on 1448 Jonny
Post 27 kohler Beavertail on 1448 Jonny
I have a 14x48 Jon boat with a 27 beavertail, right now the boat seems to plow. Has anyone tried the Beavertail pods or adding pods to see if it will help the boat plain off?
I would hope so since the pods make the boat longer and add floatation. Any feedback would be great.
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Mon Oct 18, 2010 3:10 pm
Post Re: 27 kohler Beavertail on 1448 Jonny
Wouldnt hurt to try. the only other thing is to get a longer boat.
TRYIN' TO LEAVE A CARBON FOOT PRINT!
BUMMIN RIDES AT THE MOMENT, UNDER CONSTRUCTION!
Mon Oct 18, 2010 3:12 pm
where is your gas tank and all that located. try moving all weight to the front when you run by yourself
Mon Oct 18, 2010 3:13 pm
was all in the back, I am moving it (battery and gas tank for the front)
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Mon Oct 18, 2010 3:22 pm
im runnin a 25 LT on a 1448 and it doesnt plow with jus me, and another person or two then it does! but if it were me i would go with a full huntdeck instead of pods. serves more purposes
Gatortail 1846 35hp GTR with calens stage 2 mods
Mon Oct 18, 2010 6:06 pm
have you checked your prop? it sounds like your prop is worn down to much.. that motor on that boat shouldnt have that much of a problem getting up on plane.
Tue Oct 19, 2010 2:33 am
I run the same motor on a 1444... It should not plow... it should plane but isn't extremely fast... one person, gas, battery... you should have no issue plowing... check the prop for sure...
Tue Oct 19, 2010 6:30 am
Im running A 16 hp on a 14x36 with a worn prop and have no trouble with planning off with two pep and gear. Might have some motor issues?
Tue Oct 19, 2010 7:48 am
I'm running a 27 beavertail on a 1448 jon and I get 22 mph (gps) with just me and a few gallons of gas. 2 people I can get around 18-19 depending on load. I have a custom dual exhaust, new prop and a fairly empty boat. I have never had any problems with planing out though.
Tue Oct 19, 2010 10:52 am
prop is brand new maybe has 2 hours on it, I think it might be a weight problem since I weight 210 lbs and then the gas tank and battery in back of boat.
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Tue Oct 19, 2010 2:43 pm
Yeah I weigh in about the same as you. I've got my gas tank in the front and two big deep cycle batteries in the rear. Sounds like you might be looking at some engine troubles. You should definatly be able to plane that boat out easily with that motor. Good luck!
Tue Oct 19, 2010 6:03 pm
what condition is the bottom of the hull in?
Tue Oct 19, 2010 6:25 pm
Same here im 230 and battery in the back gas tank in middle, look under the boat by the transom. sometimes the boat has a small hook by the back of the boat that will cause big prob for speeds and running
Wed Oct 20, 2010 1:46 pm
Im gonna clean the carbs real good and put some new gas in, it seems like the last time I ran it is was acting up a little like bad gas.
What about installing pods, think I should wait and see how the motor ends up, hopefully just some minor problems, but I have the trusty 25 yamaha to keep the boat in the water and keep my duck scouting/hunting.
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Wed Oct 20, 2010 6:17 pm
Please go check and see if your hull has dents in the bottom right before the braces, especially near the transom.
Before i put pods on that one, I would keep the yammerhammer on it and buy like a 16x44 gd boat for your lt.
Wed Oct 20, 2010 7:01 pm
I had one that had a dent by the transom and got another boat made all diff in the world, that how i found my prob
Thu Oct 21, 2010 7:09 am
hull is in good shape, no dents by the transom, as far as i can see no hooks in the bottom.
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Thu Oct 21, 2010 3:17 pm
do you know your rpm's? if not i'd start with a tach...i run the same size boat with a 25 and no problems planing out
Thu Oct 21, 2010 6:39 pm
what pitch prop you have
Fri Oct 22, 2010 7:41 am
Prop = 9x6
rpms = 3850-3900
I took the carbs off and cleaned, it seems like it is not getting gas or has bad spark, so I took the plugs out and they are super black, so Im gonna get new ones and replace the inline-fuel filter.
14x48 Polar Kraft
27hp Beavertail LT
25hp Yamaha
Sun Oct 24, 2010 9:37 am
BT site says to run a 9x7.... lotta guys on here say 9x6 tho...
Tue Oct 26, 2010 6:53 am
Prob. not the prop if it is in good shape though...
what they say for a 16 hp go devil
Tue Oct 26, 2010 12:31 pm
Tue Oct 26, 2010 12:36 pm
wonder if i could step up because of the super light boat and gear
Tue Oct 26, 2010 12:42 pm
