It is currently Sat Jul 05, 2025 9:46 pm
Reply to topic  [ 11 posts ]
 pro-drive power trim
Post pro-drive power trim
my powertrim om pd is very slow and making a growling sound. it makes it going up and down. after a few times it seems the motor gets hot and quits working. after it cools down it will work again w/ the same growling sound. if it is my motor any idea what one would cost? it looks like i may have to remove the motor off the boat to replace it.
Wed Oct 27, 2010 4:21 pm
Post Re: pro-drive power trim
Bad connections can create a lot of extra heat. Check all of em, both ends...
Wed Oct 27, 2010 4:24 pm
How old is your power trim? The older ones had problems with moisture getting in the motor and corroding everything. Same symptoms as your describing.
Wed Oct 27, 2010 5:08 pm
It sure will do the same thing when it gets wet!!
Wed Oct 27, 2010 5:54 pm
the motor is about two years old. i sent kp at pd a video, hopefully he will get back w/ me today.
Thu Oct 28, 2010 7:07 am
tell ya what owen, man you know your stuff. i took the motor apart and it definetly has moisture issues going on. when i talked to kp earlier he did say that they no longer use that unit. my motor is two years old, i have to see, hopefully is still under warrrenty.
Thu Oct 28, 2010 4:38 pm
I doubt it will still be under warranty because the frame is only a 1 year warranty. Call KP though and he will order you a new setup for what it costs them to get it.
Thu Oct 28, 2010 4:45 pm
yeah he said 150.00 i can live with that.
Thu Oct 28, 2010 4:48 pm
Yeah I was gonna say that it should be between 100-200$ lol.
Thu Oct 28, 2010 4:53 pm
gonna ordre one monday morn so it will be here. went to the lease in my flatboat and way to much work w/ low water conditions. good luck on your season owen.
Sun Oct 31, 2010 5:35 pm
Before you order the motor, I would check your trim switch because mine had moisture problems. Just thought i would give you the heads up to a problem that might happen later and maybe save you some on shipping.
Mon Nov 01, 2010 12:11 pm
Users browsing this forum: No registered users and 93 guests
