It is currently Sun Apr 05, 2026 4:18 am
Reply to topic  [ 15 posts ]
 Speeds
Post Speeds
What speeds are you guys getting? I just finished putting my longtail together and am looking for some comparisons so I know if things are running right. I have a beavertail longtail frame with a 33 hp generac engine on a 1652 Lowe Roughneck with pods.
I am getting 10-12 with three guys, two dogs, and all of our gear.
18 mph with just me, two kids, and two dogs
Mon Sep 27, 2010 5:47 am
Post Re: Speeds
What are your rpm's? Without a load on the trailer? With a light load? With a heavy load? If you don't have a tach, get one!
Mon Sep 27, 2010 9:34 am
Post Re: Speeds
what size prop are you running?
Should have a little more speed unloaded and alot more speed than you have loaded.
Might be over-propped.
Mon Sep 27, 2010 10:24 am
Post Re: Speeds
Did you completely build yourself? Where did you get your Generac?
Mon Sep 27, 2010 3:51 pm
Post Re: Speeds
Tue Sep 28, 2010 12:53 am
Post Re: Speeds
i bought the frame and prop used as a unit and added the generac motor that i purchased from http://stores.ebay.com/Small-Air-Cooled-Engines. I have a few feelers out there for prop recommendations. I know it is a nine inch prop but i am not sure of the pitch. the original engine was a vanguard 35 that the guy took off and put on a short shaft.
Wed Sep 29, 2010 7:44 pm
Post Re: Speeds
If i remember right
rpm on the trailer is around 4000 rpm
around 3800 with the heaier load
around 3900 with the lighter load
the prop is slightly worn which is why i am looking for suggestions on size and brand of new prop
Wed Sep 29, 2010 7:48 pm
Post Re: Speeds
I have noticed that most 31 to 35hp motors come with a 9X6. I think I might be slightly overpropped to. I carry a pretty heavy load with a full aluminum blind, 3 dozen weighted keel decoys, 2 robo ducks, 2 200+lb guys, 1 dog, battery. Running a 31hp beavertail I got 14mph average. Haven't tried it bymyself. But either I'm overpowered or the motor isn't at full power because I can tell that it seems to be bogged slightly. You should be able to hear if the motor is bogging down badly, and thats a pretty good clue you need to try a smaller prop.
Thu Sep 30, 2010 9:39 pm
Post Re: Speeds
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Thu Sep 30, 2010 10:21 pm
Post Re: Speeds
Sun Nov 07, 2010 8:00 pm
Post Re: Speeds
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Nov 07, 2010 8:09 pm
Post Re: Speeds
my mblt 35CDI runs a 9X8 on a 16X48 G3MV with 16"podds runs 20 to 22 with me (335) 18 with 2 more guys at 4205 ele
16X48 G3 MBLT BD4500
Mon Nov 08, 2010 5:12 pm
Post Re: Speeds
31Hp GDLT on a 17x42 Skiff, 3 ppl.. Me (150), Podnuh1 (195), Podnuh2, (150)
And gear @ at 21 Mph! :)
2 ppl, Full and gear @ 23mph in Deep water an 25mph in shallow.
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Mon Nov 08, 2010 9:31 pm
Post Re: Speeds
Mon Nov 08, 2010 9:50 pm
Post Re: Speeds
18x44 w/ 35 GDLT, 2 people 85lb dog and gear I get 21 or 22 mph at 3800rpm 10x6 prop
Mon Nov 08, 2010 10:27 pm
