It is currently Tue Jul 01, 2025 4:26 am
Reply to topic  [ 6 posts ]
 35vanguard fuel pump?
Post 35vanguard fuel pump?
Alright here i go. can anyone tell me what PSI the stock fuel pumps are? I have a e-pump but it is a 2-5psi and was wondering what the stock pumps where at in psi? Thanks
Prodigy 1851 elite timber , 4400 HDR .
Thu Nov 11, 2010 3:44 pm
Post Re: 35vanguard fuel pump?
1.8396251007362 PSI
Thu Nov 11, 2010 4:41 pm
Funny, For real can these e-pumps mess up the motors pump if not turned to the same psi? Got a new motor own the way and got one that i had own my old 25kohler didnt care if it messed up the old one but i do care about the new 35.
Thu Nov 11, 2010 4:56 pm
You should be fine with that pump. I run a Facet that's 1.5-4 psi and my carbs do not overflow. I do have twin mikuni's but I don't think a stock carb should have any trouble holding back 5 psi of fuel pressure.
I don't think it's a good idea to run two pumps. Other guys on here will be able to tell you for sure but if you are going to run an e pump, I would bypass the factory pump.
"We Are Products Of Our Decisions"
Thu Nov 11, 2010 5:51 pm
that was my next question hell dont even need the e-pump anyways really its a longtail.
Thu Nov 11, 2010 7:54 pm
Stock cam driven pump is 1-2PSI. Not sure what the vacuum pump on the CDI/Marine grade motors is, but its probably close to the cam driven one. If you feel the need to put on the other pump, bypass the stock one as mentioned above.
Fri Nov 12, 2010 6:42 am
Users browsing this forum: Google [Bot] and 159 guests
