music_man
 adding a fuel pump to a 35 vanguard???????
I've heard you can add a fuel pump to a 35 vanguard to give it a little more "help". Mine does great with 2 people and gear. However, when you add the 3rd person it labors (won't plane in deep water.) It will turn 34-3500 rpms loaded and 38-3900 out of the water. It has a 12.25 prop on it. Any suggestions?
Wed Nov 17, 2010 11:13 am |
BASSMASTER
Joined: Thu Jul 22, 2010 12:55 pm Posts: 1091 Location: TX
 Re: adding a fuel pump to a 35 vanguard???????
what kinda motor lt or sd?
what kinda boat do you have? mainly whats the length and width? you might need to check your weight distribution also.
_________________ Gave up hunting ducks and started underwater basket weaving!
Wed Nov 17, 2010 11:25 am |
music_man
It's a 2005 HD with the 48" shaft. I have distributed the weight as good as I can get it. I even though about trying a 11 inch prop on it. Even when it's jsut me, it still only turns around 3550 rpms. It is def laboring.
Wed Nov 17, 2010 11:42 am |
deadbird8
First thing- Turn your governor up to 4200 OOW if you are only turning 3800-3900 OOW now. Right now your governor is probably whats holding you at the 34-3500 RPM mark causing the 'laboring'.
Make sure throttle cable is giving full travel. Phillips screw driver, turn governor adjustment screw clockwise, gently raise the throttle up to see where the limit is and repeat until you are at 4200 OOW.
Wed Nov 17, 2010 1:30 pm |
music_man
Thanks, I'll try that. 4200 won't hurt it in any way? I'm just making sure, I'm very particular with my stuff.
Wed Nov 17, 2010 1:50 pm |
quackconsumer
Wed Nov 17, 2010 3:57 pm |
music_man
haha Okay, thanks man!
Wed Nov 17, 2010 4:07 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
do what deadbird said.....a fuel pump isnt gonna help you!
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Wed Nov 17, 2010 4:57 pm |
carlosd321
Joined: Tue Dec 07, 2010 8:41 pm Posts: 181 Location: Walker, La
Did this work for you? I have the 35 vanguard and I was getting like 3200 OOW. I just tried this and I got it up to 4120 OOW. Thats screaming though and it back fires some when I let off the throttle, is that normal? I guess Im just not used to it running that high maybe. I got this boat from Gator Trax in 09 when I got home and Im just now trying to get more out of it. Thanks
_________________ Bayou Gun Runner
Wed Dec 22, 2010 10:40 am |
deadbird8
Wed Dec 22, 2010 10:49 am |
carlosd321
oh ok well hope to get rid of that muffler soon when I talk to Keith. Thanks again for the great info Deadbird
Wed Dec 22, 2010 12:08 pm |
