It is currently Sat Sep 20, 2025 9:04 am
Reply to topic  [ 14 posts ]
 Boat light connector Question
Post Boat light connector Question
i have an 06 chevrolet with the round plug in adapter by the hitch. i put the '4 wire' LED wiring harness on the boat trailer and i bought the hoppy plug in adapter. i have running lights but no brake lights or turn signals.the wires are ran correctly on each side of the trailer.They work on an older toyota. what would be the problem?
Tue Mar 31, 2009 3:36 pm
Post Re: Boat light connector Question
Try hooking up another trailer to your chevy. If your chevy doesnt light up the brake, and turn signals on the second trailer, its has to be the wiring on the truck.
Tue Mar 31, 2009 3:42 pm
blown fuse on da chebby
Tue Mar 31, 2009 3:43 pm
thanks stumpgrinder, both turn/stop fuses were blown.
Tue Mar 31, 2009 4:37 pm
I've always considered myself lucky to have any lights at all... much less brakes and blinkers. :lol:
24x60 Dual Prodrives
Tue Mar 31, 2009 6:48 pm
boatless!!!!!!!!!
Tue Mar 31, 2009 7:17 pm
Tue Mar 31, 2009 8:15 pm
check the ground on the trailer you were having problems with cuz if that 'yota is a good bit older I'll put money it does not have fuses fo trailer lights. Them older trucks would burn bulbs if something was loose.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Mar 31, 2009 8:39 pm
thanks, ill keep an eye on it. I just got the truck a couple months ago and it was the first time I, myself every hooked trailer lights to it so they could have been blowed when i bought it.
Tue Mar 31, 2009 9:01 pm
Wed Apr 01, 2009 7:05 am
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Wed Apr 01, 2009 9:13 am
got the same problem....'07 toyta tacoma everything works great on boat trailer and any other trailer I have
Any other truck like my 05 Dodge 3500 nothing works if lights arent turned on, when lights are turned on everything works except the right brake/blinker
or 06 Ford F150 runnin lights will work but nothing else will work
Still blown fuses or something else? Its not just the boat trailer any trailer I have (which are all wired right and grounded)
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Wed Apr 01, 2009 9:24 am
Wed Apr 01, 2009 10:49 am
I was going to suggest checking the bulbs since they have 2 elements, 1 for running lights the other for stop/turn signals.
As far as trailer working on one truck and not another I have no idea. Might try buying a cheap .22 bore brush and cleaning the female connections real good and emery cloth or sandpaper on the male ends
OneBigAssMistakeAmerica
Wed Apr 01, 2009 12:27 pm
