It is currently Wed Jul 02, 2025 8:37 am
Reply to topic  [ 12 posts ]
 BPS Single Mikuni Kit large block 35 Vanguard how difficult?
Post BPS Single Mikuni Kit large block 35 Vanguard how difficult?
Hey guys was looking to buy one of these kits would it be better to let someone put it on or can you put it on yourself? thanks for the help.
35 GTR on Uncle J 18/54
Thu Dec 09, 2010 12:25 pm
Post Re: BPS Single Mikuni Kit large block 35 Vanguard how diffic
Putting it on is easy, tuning it can be tricky. They are supposed to come set up and ready to go, just a few turns on the a/f screw. Sometimes it's not that easy, having someone who knows there chit around to help would be nice.
Thu Dec 09, 2010 12:28 pm
my plan is to put exhaust on it and the carb if i buy the carb from setx performance do i need to get anything or will my motor be ok like that im new this is my first mud motor.
Thu Dec 09, 2010 1:11 pm
setxpreformance.com ask for Keith... Very down to earth guy and knows his Sh!t... He has my carb now doing some work on it so I can install it next week... Just go to the site and give him a call!!
Thu Dec 09, 2010 1:18 pm
ok man thanks. thats where i plan on buying it from just wasnt sure about if in need more than what came with it but i will give him a call and see what he says. thanks TDUET
Thu Dec 09, 2010 1:24 pm
Keith will let you know if there is anyhting else you may need to install it.. prolly wont need much other than the kit, unless you want a new throttle lever and the other goodies he has... lol
Thu Dec 09, 2010 1:30 pm
The BPS kit will come with everything ya need. Unless it's changed, you will have to change out the jet yourself, but the replacement is included in the kit, along with the instructions on how to change it. ;) I also orderred the BPS throttle lever with mine & changed them both @ the same time. I say go for it, if ya got the $$$, & order up the carb / exhaust /prop combo.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Dec 09, 2010 1:40 pm
Im hope'n he can make the BPS throttle work for a GTR.. As of now I dont think they mount up... But he said he would try to make it work. Its way better than that plastic crap I have!
As for having to change out the jets.. Keith will do that as well if you want.. Its what he is doing for me.. All im doing is installing it... Let him know what you want/need and im sure he will do his best!
Thu Dec 09, 2010 1:44 pm
Cool guys well i think thats the way i will go and i been thinking about that BPS throttle lever too i might just have to do that too man cause that thing seems alot better than the plastic one that is on there now. Thanks guys for the help im hopeing to get everything all set up so me and 3rd coast killer can take a trip out to yalls way and make the setx run in feb im a newbe so will prob get stuck alot but its always a good time on the boat and i will be sure to bring a rope lol
Thu Dec 09, 2010 1:54 pm
All ya have to do with the throttle is take a grinder to it & make it open up to a bigger diameter, or bring it to a machinist & have them do it. As far as changin out the jet, it's really simple to do as well. If ya in Houston area, just bring ya boat by when ya pickin it up & it can be done on the spot. Only takes about an hour or so to do the carb. Throttle lever will take a lil bit because it has to be done on the spot. Exhaust takes no time. We can even take it right down the road & run it afterward so ya can see the difference!!!
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Dec 09, 2010 2:00 pm
shoot that sounds like a plan man i let you know for sure thanks camo
Thu Dec 09, 2010 2:48 pm
If you have a CDI motor, specify that when you order.
The BPS kit is a complete bolt on and probably the most esoteric tool you need for install is some snap ring pliers for the governor shaft.
I prefer the plastic handle myself, I just took the dremel to it and cut off the square point to make it more comfortable to drive.
Sat Dec 11, 2010 10:28 am
Users browsing this forum: No registered users and 166 guests
