It is currently Tue Jul 01, 2025 8:13 am
Reply to topic  [ 6 posts ]
 Losing Power on GDSD 23...
Post Losing Power on GDSD 23...
OK guys, here's my problem. I have a 23hp GDSD that is two years old. I am running the single mikuni carb with the BPS crossover exhaust and a big blade prop. Everythign runs and works fine until I have been running for about 10-15 minutes or so and then it acts like it runs outta gas. But, I can immeadiately re-start it and go again for about 2-4 minutes and then repeat. What is a possible cause of this??? I have already replaced the spark plugs, fuel pump, shortened the fuel line from a 14' hose front mount tank to a 2.5' hose and rear mounted tank and new fuel filter. Motor starts up fine and sounds fine when running, it's just like it's getting starved for fuel?? Thanks
Dave
Wed Dec 15, 2010 6:10 pm
Post Re: Losing Power on GDSD 23...
Do you have an aftermarket Rev box or mikuni on it, need to know more info about your engine to diagnose the problem.
Wed Dec 15, 2010 6:33 pm
18x48 EXTREME w/ 35GTR MARSH MELLOW XX
Wed Dec 15, 2010 6:37 pm
Possible pinch line, or getting air maybe. Mine will fire up sometimes, and just not pull a vaccum on a cold day.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Wed Dec 15, 2010 6:40 pm
Sounds like a dirty carb. Pull it and clean it good. If it's got trash it will run fine on startup but will suck up trash in a jet after a few minutes. High oil level will result in overheating the engine.
Wed Dec 15, 2010 6:46 pm
Buddy had same problem, ran fine for the first 5 min and then after hott it would start messing up, clipped green wire on Rev. box and it ran awesome, thats why i ask if you have aftermarket rev box, just a solution
Wed Dec 15, 2010 6:48 pm
Users browsing this forum: Google [Bot] and 146 guests
