It is currently Tue Jul 22, 2025 12:26 am
Reply to topic  [ 26 posts ]
 Fireplaces
Post Fireplaces
Anybody around these parts know much about fireplaces?
Mine decided to start letting smoke back into the house and I dont know why -- there has always been a slight smokey smell in the house but nothing more than I normally smell when I go to a house with a fireplace. Well I can see the smoke coming out the front of the fireplace -- that sucks cause I love my fireplace
Wed Jan 12, 2011 8:41 am
MMT Moderator
Post Re: Fireplaces
Creosote build up? you may need the expertise of a professional chimney sweeper. They make creosote cleaning logs too. The wind can do it too (blow smoke back in) but usually its because its not breathing right
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jan 12, 2011 8:43 am
Post Re: Fireplaces
If the flue is not designed right it could allow air back into the house. IS it old hand made or manufactured new style?
Could be plugged up also. Cleaned it lately?
Best thing is to try CSL. http://cleanyourchimney.com/ If it's really bad, get a professional chimney sweeper.
Copperhead 12Hp SD on 1442 Alweld
Wed Jan 12, 2011 8:45 am
Post Re: Fireplaces
You must have some problem with the smoke getting out. Those things are designed where there will be less pressure up than in the fireplace itself or in your house, thus making the smoke want to go up though the chimney.
So I would guess you have a nest of some sort, extreme build up of soot, or maybe even a dead animal lodged in the chimney that is preventing the smoke from leaving freely. One would think this would especially be the case if this is a new problem.
Good luck getting it fixed.
36 PD 1852 Brother Breaux
Wed Jan 12, 2011 8:50 am
Post Re: Fireplaces
Are you running the heater/fan in your house? The return air may be sucking air in from the chimney, thus pulling in the smoke. I had that issue at my 1st house. We couldn't run the fan/heater at the same time the fireplace was lit.
Wed Jan 12, 2011 9:03 am
Post Re: Fireplaces
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Wed Jan 12, 2011 9:05 am
Post Re: Fireplaces
Its an insert -- this is the 3rd year and I havent cleaned it proper -- just with a log
The smoke has always gone out no problems -- there is a screen around the top so no animals or birds can get in.
This is the 1st fireplace Ive had that wasent a brick fireplace, I dont like it nearly as much as a good built in brick fireplace,
Wed Jan 12, 2011 9:20 am
Post Re: Fireplaces
You sure the baffle is opening that leads from the fire box to the chimney stack?
Wed Jan 12, 2011 9:27 am
Post Re: Fireplaces
LOL --- Yea -- Im sure -- its not ALL coming in just some of it
What -- You think Im from SETX or Tennessee or something?
Wed Jan 12, 2011 10:00 am
Post Re: Fireplaces
Uncle J 1848 w/?
Wed Jan 12, 2011 10:14 am
Post Re: Fireplaces
I am in love!!!! :shock:
Wed Jan 12, 2011 10:29 am
Post Re: Fireplaces
Wed Jan 12, 2011 12:34 pm
Post Re: Fireplaces
open a door when you first light it. that will alow the air to move freely out the flue. once the flue heats up some it will draft properly. if its not a start up problem, id check the condition of the flue. as stated it may need to be cleaned. you should clean it at least once a year. it depends how much you use it and what you burn. ive used my stove heavy for two years w/o cleaning burning only hard wood and it wasnt all that coked up.
Wed Jan 12, 2011 3:44 pm
Post Re: Fireplaces
Sure you aint burning green wood? Cause that will do it. More smoke and less heat to rise up causing draft=smoky house
Wed Jan 12, 2011 4:29 pm
Post Re: Fireplaces
If you use it much at all you gonna be surprised at how much buildup you have in it after 1 year, let alone 3. That thing needs a proper cleaning after every season.
18x48 Charles Leonard / 36PD
Wed Jan 12, 2011 5:15 pm
Post Re: Fireplaces
Like everyone said,Check that it doesn't need cleaning!If the wind is blowing bad you must build a hot fire to overcome it!Make sure to have a hot fire also if the wife is running the dryer,stove vent,bathroom vent,or anything else that sucks air from house!!Hope this helps!
Wed Jan 12, 2011 5:55 pm
Post Re: Fireplaces
Wed Jan 12, 2011 6:47 pm
Post Re: Fireplaces
Havent cleaned mine in 5 years....ya'll think it's time? :shock:
Wed Jan 12, 2011 6:52 pm
Post Re: Fireplaces
When you get home to see the FD standing around what once was your house you will know it was overdue........... :lol:
Wed Jan 12, 2011 7:18 pm
Post Re: Fireplaces
Wed Jan 12, 2011 8:27 pm
Post Re: Fireplaces
home depot has the brush and extention poles. not that hard to do.
Thu Jan 13, 2011 8:10 am
Post Re: Fireplaces
hey im new on here and from SETX ...what are these "fireplaces" you talk about?
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Thu Jan 13, 2011 8:17 am
Post Re: Fireplaces
Thu Jan 13, 2011 8:53 am
Post Re: Fireplaces
Thats why I love my gas fireplace. No smoke, no logs, no mess!
1754 Xtreme 35 GTR Stage 1
Thu Jan 13, 2011 9:09 am
Post Re: Fireplaces
The only gas I have in my house is when I eat beans or cabbage
Thu Jan 13, 2011 10:02 am
Post Re: Fireplaces
Nothing like the real thing ;)
Thu Jan 13, 2011 12:32 pm
Users browsing this forum: No registered users and 103 guests
