It is currently Sat Jul 05, 2025 7:00 pm
[ 9 posts ] |
Buddman
Joined: Thu Dec 09, 2010 8:16 pm Posts: 96 Location: Morgan City, LA
 repair manual
Does anybody know where I would be able to find a repair manual for a 36hp Briggs w/ detailed repair procedures ,torque specs , ect... ?
Wed Feb 23, 2011 8:06 pm |
caddobrook
 Re: repair manual
Wed Feb 23, 2011 8:25 pm |
Buddman
 Re: repair manual
I saw the parts list and owners manual. I'll try to dig a little deeper. Thanks.
Wed Feb 23, 2011 8:27 pm |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
 Re: repair manual
35/36 Briggs Torque Specs:
Head Work: Valve Cover 70 in. lbs (8 Nm) Rocker Arm Stud 100 in. lbs (11 Nm) Rocker Arm Lock Nut 70 in. lbs (8 Nm) Cylinder Head 350 in. lbs (40 Nm) Exhaust Manifold 180 in. lbs (20 Nm) Intake Manifold 180 in. lbs (20 Nm) Cylinder Shields 90 in. lbs (10 Nm) Spark Plug 180 in. lbs (20 Nm)
These come from the Briggs Repair manual which you have to purchase, I have not found them on-line. Carb and Intake: Intake Manifold 180 in. lbs (20 Nm) Carb to Manifold 90 in. lbs (10 Nm) Carb Intake Elbow to Carb 90 in. lbs (10 Nm) Air Cleaner Base to Carb 65 in. lbs (7 Nm) Air Cleaner Support Bracket 65 in. lbs (7 Nm) Air Cleaner Mounting 190 in. lbs (21 Nm) Air Guide Mounting Screws 90 in. lbs (10 Nm) Air Block Plate Mount Screws 90 in. lbs (10 Nm)
Flywheel and Fan: Flywheel 150 ft. lbs (203 Nm) Flywheel Fan Screws 90 in. lbs (10 Nm) Ignition Armature 30 in. lbs (3 Nm) Armature 35 in. lbs (4 Nm) Rotating Screen Studs 125 in. lbs (14 Nm) Rotating Screen Screws 100 in. lbs (11 Nm) Alternator 35 in. lbs (4 Nm) Voltage Regulator 90 in. lbs (10 Nm)
Engine: Oil Pump to Crankcase Cover 90 in. lbs (10 Nm) Oil Pickup to Pump 90 in. lbs (10 Nm) Oil Pressure switch 80 in. lbs (9 Nm) Oil Drain Plug 180 in. lbs (20 Nm) Governor Control Bracket 200 in. lbs (23 Nm) Governor Lever Nut 70 in. lbs (8 Nm) Fuel Pump 45 in. lbs (5 Nm) Connecting Rod 125 in. lbs (14 Nm) Crankcase Cover 200 in. lbs (23 Nm) Starter Motor 140 in. lbs (16 Nm)[/quote]
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
Wed Feb 23, 2011 8:28 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: repair manual
Wed Feb 23, 2011 8:29 pm |
Buddman
 Re: repair manual
Thanks for the info guys. Having these torque specs was the main thing, now I won't have to get in as big of a rush to get the repair manual.
I appreciate it.
Wed Feb 23, 2011 8:41 pm |
deadbird8
 Re: repair manual
Thu Feb 24, 2011 4:56 am |
Buddman
 Re: repair manual
And thank you Mr. DB
Thu Feb 24, 2011 5:41 am |
muddiejeep
 Re: repair manual
sorry forgot to give the credit to gary on that one.
Thu Feb 24, 2011 8:26 am |
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 163 guests |
