It is currently Wed Sep 24, 2025 12:54 am
Reply to topic  [ 26 posts ]
 Removing the skeg guard on a pd36
Post Removing the skeg guard on a pd36
I am not sure what you call it, but it is the welded strip of metal on the very bottom of the skeg on a PD36. The very end of this piece is worn enough that sometimes I have to bend it back straight with a hammer because it starts to contact the prop. Some people I know remove the entire strip for supposedly a little better performance.
My question is for those who have removed it, how difficult is it and what is the best way to remove it....grinding wheel?
Thanks
Thu Mar 03, 2011 8:29 am
Post Re: Removing the skeg guard on a pd36
If you remove the entire strip you will eat up your skeg up because it is aluminum. The mudbuddy and go devil skegs aren't aluminum, don't know about gt. Thats why they don't eat up. If you want the little better performance grind the strip down so that it isn't as wide on the edge, and cut the end off sticking under the prop. That will make your prop come in more contact with whatever you hit though. I personally don't think you will see a noticable difference in performance.
1754 Gatortail with 35 GTR
1748 prodrive pushed by a genny (SOLD)
I shoot black mallards does that make me guilty of a hate crime?
Thu Mar 03, 2011 2:20 pm
Thu Mar 03, 2011 2:25 pm
Thanks fellas
Thu Mar 03, 2011 3:12 pm
if you take it completely off to run lillies it will make a world of a difference.... But if you hit logs it can and will eventually break the lower unit.
my buddy ran lillies with his off that I could only look at!
I gave up mud motors
Thu Mar 03, 2011 5:57 pm
I guess it would wear pretty good, if you drug it down the highway. But I don't see any on mine I been running for a good while now. If you run hard bottom you can get down more for a better bite and the flatter angle catches less veggies at slower speeds. This is a BayouBoy made skeg. I'll cut them off mine from now on.
18x48 Charles Leonard / 36PD
Thu Mar 03, 2011 6:01 pm
Did Preston just trim the factory one? Or is it made out of all new and different material?
Thu Mar 03, 2011 7:09 pm
Heres mine, Its bent all to hell, in the wrong direction. lol god damn stumps!
Thu Mar 03, 2011 7:14 pm
New one he made, same material. It can still bend on a hard stump impact but runs better IMO.
Thu Mar 03, 2011 7:36 pm
Preston's is made of stainless.
Thu Mar 03, 2011 8:20 pm
Thu Mar 03, 2011 8:49 pm
36hp pro-drive pushin a 1748 rick aucoin skiff
1500hp Mitsubishi pushing a 50' push boat
200merc pushing a 20' Mako
Thu Mar 03, 2011 9:35 pm
Thu Mar 03, 2011 9:43 pm
Thu Mar 03, 2011 9:44 pm
Fri Mar 04, 2011 5:37 am
Fri Mar 04, 2011 8:48 am
Just put a BFW on it and bend it back.
Fri Mar 04, 2011 9:53 am
BFW? I can imagine what BF means but what is the W for? Whack? :D
Fri Mar 04, 2011 11:23 am
wrench
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Fri Mar 04, 2011 11:26 am
:idea:
Fri Mar 04, 2011 11:36 am
Fri Mar 04, 2011 6:37 pm
I use a big cresent wrench to bend mine when needed. No heat.
Fri Mar 04, 2011 7:31 pm
Sat Mar 05, 2011 4:51 pm
Ya'll are both right its 1/4 aluminum with the bottom wrapped in 3/32 stainless plate. ;)
Sat Mar 05, 2011 11:19 pm
bb how much 4 one got a new pd thats just needin one bad lol
driving a gd in ur lake
and i aprove this message
Sun Mar 06, 2011 9:18 am
Sun Mar 06, 2011 6:58 pm
