It is currently Fri Jan 30, 2026 5:41 pm
Reply to topic  [ 3 posts ]
 intermitent ignition on 23 hp vanguard
Post intermitent ignition on 23 hp vanguard
Anyone have any insight on what might be the problem?
Battery is full charged and connections have all been cleaned and checked.
I have 12+ volts up to the point it connnects to the black block with 2 studs on it. Sometimes it will start and other times nothing but need to figure it out so I can trust it on the river with fast current.
I am thinking key switch or the black block but not sure, starter seems fine.
Thanks 1 duckcrazy
Mon Apr 27, 2009 5:24 pm
Post Re: intermitent ignition on 23 hp vanguard
If your talking about the starting circuit, you probably need to pick up a new solenoid. Next time it gives you problems hit the black thingy with the handle of a screw driver and see if it cranks.
Mon Apr 27, 2009 6:21 pm
Tue Apr 28, 2009 10:46 am
