It is currently Sun Mar 29, 2026 3:23 am
Reply to topic  [ 7 posts ]
 shaft angle
Post shaft angle
Hey guys im starting a 25hp LT project and have got alot of the info i need from this forum. But i was needing a angle of the drive shaft from the motor. I dont have acces to any mud motors where im from to copy off of. Its going to be on a 16'' transom and 72" shaft so anything close would be great im guessing its going to be around 15-20 deg.
Sat Apr 09, 2011 3:35 am
Post Re: shaft angle
13 to 15 degree is the range you probably want
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Apr 09, 2011 7:14 am
anybody else.......im going to go with average so everybodies anwser helps
Sat Apr 09, 2011 9:34 pm
Ive heard 13 is the magic number.
Sat Apr 09, 2011 9:47 pm
i always figured itd best to worry about the length of the shaft more than the angle. the longer shaft is gonna gove u more forward power. the less of an angle on the ujoint, the less the restriction and more power goin to the shaft. the only point for really even having an angle et the ujoint is to keep the motor balanced.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Sat Apr 09, 2011 9:54 pm
so we all agree 13 deg.?
Wed Apr 13, 2011 11:16 pm
I went 16 degrees on mine. Works pretty good. That's with a 72'' shaft.
Fri Apr 15, 2011 4:29 pm
