Bootzz
Joined: Tue Jan 13, 2009 6:12 pm Posts: 499 Location: DA BACK OF DA BACK,Louisiana
 please help!!!!!
ok so we got a c20 mud truck....well went mudin and cliped the keys fot the truck to my belt loop and somehow ridin the fourwheelers and wrestlin in the mud i lost the ONLY KEY!!!!.....any one here can tell me how to unlock the steering column and start it??......i know how to bypass it all but i dont wana lock my steering column up .......is this truck old enought to just shove a screwdriver in the ignition and itll turn???
Sun Apr 24, 2011 8:57 pm |
Bootzz
 Re: please help!!!!!
cmon guys someone has to know
Sun Apr 24, 2011 9:05 pm |
Woodiebuster
Find the key and make a copy.
Sun Apr 24, 2011 9:10 pm |
aweyerman
Joined: Fri Sep 17, 2010 11:32 am Posts: 411 Location: Ohatchee, Alabama
Get your vin number and get a new one from the dealer OR find a good lock smith to make you one.
_________________ 1648 Tracker 50 Merc Team Topwater-Alabama
Sun Apr 24, 2011 9:18 pm |
riverratdm84
Joined: Fri Jul 30, 2010 3:15 pm Posts: 701 Location: pella, ia
u can put a new lock cylinder in but its harder without the key
Mon Apr 25, 2011 4:53 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
_________________ I gave up mud motors
Mon Apr 25, 2011 5:14 am |
quackconsumer
What year model is the truck?
Mon Apr 25, 2011 5:42 am |
Bootzz
Mon Apr 25, 2011 9:09 pm |
Bootzz
Mon Apr 25, 2011 9:26 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
a screw driver should start it
Mon Apr 25, 2011 9:31 pm |
jp0242
Joined: Wed Jan 19, 2011 6:38 am Posts: 184 Location: belle chasse, la
only one way to find out
Mon Apr 25, 2011 9:57 pm |
Bootzz
ok so its an 83...put a scre driver in it and nuttin....how hard do i have to shove it in?? i tried just puttin it in but someone said knock it in with a hammer??? ive never had this problem before so all advice helps.....i tried small screwdrivers and big ones....but all i did was push them in...do i try hitin them with a hammer into the ignition?
Mon Apr 25, 2011 10:52 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Maybe some of DGuidry's clients can chime in on how to hotwire it.
Mon Apr 25, 2011 11:01 pm |
cb5331
You can mount a couple toggle switches to turn on the ignition and accessory circuits, and a push button to turn the starter. I don't know if you have a steering wheel lock or not and don't know how to bypass that if you do. I'm sure it can be done though... www.the12volt.com should have a wiring schematic for the ignition harness.
Tue Apr 26, 2011 6:40 am |
MaXXis85
I havent messed with an old chevy in a while, but u can change switch, Or there is something you can break and it will allow acces to turn the ignition witout a key. That also gets rid of the steering wheel lock. But them old trucks are so simple to make things work just get in there and figure it out.
You must be getting ready to go to Duhons on Sunday huh?
Tue Apr 26, 2011 6:47 am |
T-Bubba
take da key switch out and put a push button
Tue Apr 26, 2011 7:12 am |
tchredneck
Joined: Tue Jan 13, 2009 7:39 pm Posts: 1812 Location: in the woods,la
its just a lock cylinder bust it out, twist with plyers ,back in buisness
new lock cylinder prob 80 bucks if you can find one
_________________ 27 Contender twin 200's for sale 18x42 B.B skiff Lil daddy 36 pd Fighting da Koolaid brigade since 07'
Tue Apr 26, 2011 7:21 am |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
Its a mud truck --- Put a toggle to turn on battery and a push button to start it -- Just by pass that key and bust the lock
Tue Apr 26, 2011 7:26 am |
Bootzz
Tue Apr 26, 2011 8:47 pm |
kibb
Put a screwdriver with a square shank in it and turn it with a crescent to break it.
Wed Apr 27, 2011 5:42 am |
tongthrower
Joined: Wed Jan 14, 2009 8:36 am Posts: 672 Location: Houston, TX
_________________ EVT Stage 1 32PD on a 17x48PD "I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me." Mike Huckabee
Wed Apr 27, 2011 4:11 pm |
