It is currently Tue Sep 23, 2025 7:59 am
Reply to topic  [ 9 posts ]
 New Prodrive Grease Fitting
Post New Prodrive Grease Fitting
I saw a Prodrive ad that showed a new zerk fitting on the lower unit that mine does not have. It must be something new on the 2011 models. It is on top of the LU facing up, right before where the cavitation plate meets the LU. Anyone know what it's for?
Fri Jun 17, 2011 9:31 pm
It greases the shaft that connects to prop
35 Mud Buddy ON 1652 WELDCRAFT
Sat Jun 18, 2011 5:51 am
Post Re: New Prodrive Grease Fitting
Just like the 08 addition of the upper grease bearing / seal, they added one to the lower bearing now. Trying to stop the seal leaks by the added grease pressure I guess .
18x48 Charles Leonard / 36PD
Sat Jun 18, 2011 9:34 am
It's a grease seal between the hard seal like the gd
And I drive a pd and approve this message
driving a gd in ur lake
and i aprove this message
Sat Jun 18, 2011 1:49 pm
The gear case is now sealed off from the prop shaft. The prop shaft housing is grease filled instead of oil filled so that when the lower prop shaft seals get bad it doesn't let water into the gearcase. They r new as of 09/2010. I got one of the first ones, by chance.
18'x54"CC Hanko/ 36PD
Sat Jun 18, 2011 2:09 pm
Sat Jun 18, 2011 5:54 pm
Both the upper spline and lower prop shafts are now greased filled and the gears are still oil bath. No need for the vent on top either they come plugged now. I've been running one for a while and its the best thing since sliced bread imo. Just remove the bottom plug ( where you use to drain the gear oil) and pump grease until it comes out clean. So now if your prop seals go out it will just leak grease and not allow water get in the gear housing.
Sat Jun 18, 2011 10:17 pm
Wut he said!
Sun Jun 19, 2011 2:59 pm
Gotcha, just the shaft and not the whole LU.
Sun Jun 19, 2011 3:01 pm
