It is currently Tue Jul 08, 2025 1:01 am
Reply to topic  [ 4 posts ]
 Sand on surface drive
Post Sand on surface drive
I was just curious if sand is really bad on a surface drive mm?
Mon Jul 04, 2011 10:34 am
Post Re: Sand on surface drive
Seriously?
If you run sand, you're gonna burn thru some props. If you hit a sand bar, it's probably gonna land you on your azz in the front of the boat when it comes to the abrupt stop. Other than that, I can't think if anything else it'll hurt just by passing thru it.
Sent from my Droid because I'm trying to be as cool as you someday.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jul 04, 2011 10:40 am
Mix about 1/4 cup of sand with your engine oil and your mm will be able to run through sand like a chainsaw through butter.
Mon Jul 04, 2011 11:24 am
I run lots of sand and gravel with a Prodrive rock guard. You can't run as shallow but it will go just fine as long as you got at least 8" of water. Get a rock guard so you don't push your prop into the sand it will go good.
http://www.locked-up.com
Locked-Up DVD Series
"Finishing Birds Is Everything"
2054 SBX Prodrive with a 36.
http://www.turkeytrackoutfitters.com
Mon Jul 04, 2011 1:07 pm
Users browsing this forum: No registered users and 119 guests
