It is currently Mon Jul 07, 2025 11:49 pm
Reply to topic  [ 13 posts ]
 Iron mountain heads issue
Post Iron mountain heads issue
I have a set of iron mountains on my 31 lt with approx. 50 hours on them. Has anyone had issues with them after so few hours. I did a leakdown test on mine and have some leakage out of exhaust and excessive leakage from intake! What's the problem? Possible anything I did?
Wed Jul 13, 2011 11:46 am
Post Re: Iron mountain heads issue
valves could just be loose. adjust or check and see what they are at
Wed Jul 13, 2011 11:52 am
Do a leak down test.
Wed Jul 13, 2011 4:37 pm
Valves are at .005 intake and exhaust. I did a leakdown test ( stated in original post) I put cylinder 1 Tdc and just to make certain took the rocker arms off my push rods.
Wed Jul 13, 2011 6:00 pm
Wed Jul 13, 2011 6:03 pm
Wed Jul 13, 2011 6:29 pm
Yeah I figured I was going to need a valve job but 50 hours on pretty expensive heads and already failing!! Not real impressed
Wed Jul 13, 2011 7:21 pm
Wed Jul 13, 2011 7:23 pm
you see this all the time ie dont buy iron mountain heads??? should have done a little more research
Wed Jul 13, 2011 9:13 pm
Wed Jul 13, 2011 9:15 pm
Wed Jul 13, 2011 9:26 pm
thanks, appreciate the insight
Wed Jul 13, 2011 9:28 pm
We used to fix the briggs 3.5hp in ag class all the time. Take the head off put stem in a drill and put lapping compound on the valve head and spin it in the seat. Do that a few times and clean the compound off and you gotyourself a new valve seat. Im sure the same process can be done. Just dont scar the valve stem up.
Thu Jul 14, 2011 5:59 am
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 99 guests
