It is currently Sun Jul 06, 2025 4:58 pm
Reply to topic  [ 8 posts ]
 spark plugs lean or rich?
Post spark plugs lean or rich?
I got a MM exhaust and mikuni. I been running it for a few months so I checked my plugs today to see if I was running rich or lean and one plug is black while the other looks light brown or tan (nice). Im running a 167.5 jet thinking about go down to a 165. What do you vets think about it?? its on a Prodrive with denso iridium plugs.
18x54 ProDrive boat with 36 FPR ProDrive
Mikuni, MM 2x w/baffles
Wild 'n Out!! Tear'n CHIT UP!!
Thu Jul 21, 2011 9:00 am
Post Re: spark plugs lean or rich?
Keep it where it is. One cylinder will always run a little leaner then the other. I have the mikuni on mine and many other mods and also run the 167.5.. You could try a 165 but its better IMO to run it a little rich then lean. You dont want one side to be paper bag brown color and the other side almost white. I think where you have it should be fine
Thu Jul 21, 2011 9:04 am
thanks much fowl. I my self prefer and feel safer running a lil bit rich then running lean.
Thu Jul 21, 2011 4:19 pm
You check plug color by warming up, installing new plugs, and running (no idle) for about 2 miles and then immediately kill it (pull kill switch- no idle). Then pull and check the ring at the base of the insulator.
Pulling them after you have run them and idled is not telling you anything.
Thu Jul 21, 2011 6:54 pm
DB8 is correct running a motor for a long time and pulling the plugs is not the proper way to read plugs. As he says warm it up. Throw a new set of plugs in run it full throttle for a couple miles kill it on plane with no idle, pull the plugs and read them. Take 6 - 8 plugs and different jets with you if you want to tune it to the optimum.
Russ
Thu Jul 21, 2011 8:51 pm
ok I will have to get some more plugs and I willl get back with yall.
Fri Jul 22, 2011 5:53 am
Looking for this:
Sat Jul 23, 2011 9:26 am
What determines if you need a colder or hotter plug. I'm running NGK cs6 plugs on a stock 35. Plugs have a little black but they are not all fouled up either.
18x44 Gator Trax, Stage 2 Mudbuddy
Mon Jul 25, 2011 11:34 am
Users browsing this forum: No registered users and 133 guests
