It is currently Mon Jul 07, 2025 12:53 am
Reply to topic  [ 72 posts ]  Go to page Previous  1, 2
 Stage III longevity v/s stock
Post Re: Stage III longevity v/s stock
Thu Jul 28, 2011 6:51 am
Post Stage III longevity v/s stock
17x48 extreme stage 2 GTR
Thu Jul 28, 2011 6:55 am
Hey Terry kiss my arse, just because you have blown 2 motors cause you don't know what the hell your doing...hahahahahaha just jacking with ya big guy, there's more to it then just rods and pistons, that was just an idea of what i was thinking of doing, i use my boat alot during hunting season and for work building blinds, so i'm not gonna jeopardize my reliability just to go fast, but i would like a little more load carrying capability, if i wanted a speed boat then i'd go out and get me one, but i'm a hunter not a racer
Thu Jul 28, 2011 6:59 am
You advanced your timing yet!!
My motor All my bow fishing equipment 12 gallon gas 2 batteries icechest 20 redfish 4 people 24 mph at 4200 rpm!! Stage one!!
Thu Jul 28, 2011 7:10 am
When I did my mods I maybe gained 2 mph top end not a big deal.. I did however go from 16 mph with 4 guys in it back to 26 or so. Which is where I was running 1 guy on a stock motor. I don't think I gave up any reliability if anything My motor runs better. It definetly Idles better and starts easier
Thu Jul 28, 2011 7:18 am
If you do things right and and don't try to overgrind or get to aggressive you should be fine. I love the load push on my motor. I don't play nearly as much as I hunt and most often w/ a big load.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Thu Jul 28, 2011 9:26 am
Well ima go with it!
Terry yeah we discussed advancing the timing and see where that puts my motor as it sits, i have such a lite boat already and it moves pretty good, with me and another guy running keith lake the other day i ran hit 32 at times
Thu Jul 28, 2011 10:20 am
Thu Jul 28, 2011 11:04 am
Yeah ima see about the timing Terry!
Thu Jul 28, 2011 11:05 am
I put a 3 degree tiiming key in mine.. Seems to run better. I was told to run it both ways cause some motors take to them and others will not.
Thu Jul 28, 2011 11:15 am
3 degree or number 3?
Thu Jul 28, 2011 11:16 am
With a new prop it turned 4800 !!
Thu Jul 28, 2011 11:17 am
3 degrees. With a new prop I can bump my 4550 or whatever it is Rev limiter.
Thu Jul 28, 2011 11:22 am
mine has a 3 on it is the a number 3 or 3 degrees
Thu Jul 28, 2011 11:28 am
I was told 3 degrees.. I could be wrong. Mine also has a 3 on it..So maybe its just a number and doesn't represent degrees. Would have to ask EVT thats where I got mine from.. Craig or DDM would know..
Thu Jul 28, 2011 11:30 am
The number is not the same as the degrees.
Thu Jul 28, 2011 1:05 pm
Thu Jul 28, 2011 2:10 pm
Thu Jul 28, 2011 2:13 pm
Thu Jul 28, 2011 5:17 pm
Thu Jul 28, 2011 10:47 pm
a block from the factory has been assembled by low paid workers or maybe even automated machines who dont give a flying f uck if it breaks or not, due to the rough edges
slightly modded engines run better than stock plain and simple, I found they run smoother and healthier, now a motor with sleeved pistons ect....arnt many motors made to scream 5500 rpms all day long and stay together.
to me the way they cast the blocks is a piss poor operation. just remember as the prices go up on EVERYTHING companies usually try to save a few bucks on the making process to not dramatically raise prices on the product.
If I blow this block up...330ish hours since modded, I'll do the same to my next. warranty or not. when hunting public it is a race to the finish line every morning.
27 Contender twin 200's
for sale
Fri Jul 29, 2011 3:02 pm
18x44 Gator Trax, Stage 2 Mudbuddy
Fri Jul 29, 2011 8:59 pm
He got a Stage 1 from hoyt. Heads, cam, exhaust. It is simple reliable, and makes good power. When My stock cam rouned a lobe off, Hunter towed my boat in and Got his boat on step. Yep he was towing my rig at 19-20 mph GPS.
Mon Aug 01, 2011 6:32 am
That's some serious to power. I'm impressed
Mon Aug 01, 2011 6:50 am
Mon Aug 01, 2011 3:30 pm
well I myself have the 45 and the only problem i have is it drinks more fuel but it is much better pushing my heavy boat over stumps and logs from a stand still when i get caught off guard. Speed is not something your gonna get from mods alone with out a prop. and they only put so much pitch on a MM prop. hope this helps im not a huge MM guru this is just my experience.
Starting to wonder why my mother always called me special.
1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust
premium oak reverse w/minnkota cruise control
Mon Aug 01, 2011 3:58 pm
I saw a post by esh titled prop repitched. He picked up 4mph having his 12.25 big blade tried up and pitched to 11.225. I think he said 31mph at 3900-4000 rpm. Cost $170. Can't beat that. Makes me wonder. Since my motor stock. If I went with the smaller 11x10 prop and pitch it to 11.255 if I'd see similiar speed increase. Right now I have the Big Blade on.
Wed Aug 03, 2011 11:30 pm
Thu Aug 04, 2011 6:55 am
Brink to my knowlege he hasnt had any issues with his mods.
Thu Aug 04, 2011 7:40 am
Thu Aug 04, 2011 3:45 pm
Thu Aug 04, 2011 8:34 pm
I had it progressively added to the pitch. Like changing your final drive to a numerically lower set or putting larger diameter tires on.
Thu Aug 04, 2011 10:43 pm
Users browsing this forum: No registered users and 68 guests
