mrmallard13
Joined: Mon Aug 08, 2011 7:43 pm Posts: 276 Location: Taylorsville,MS
 Best motor for my boat
I have a 1448 monarch. Its an older flat bottom Jon boat. I was looking to put a surface drive on it. What would be the best brand and size to put on? I have a 35 evinrude on it now. I will hunt mostly Lillie pads but will also hunt some timber. Any help would be appreciated.
_________________ 17x51 Prodigy with 37 efi hdr delta level 3
Thu Aug 11, 2011 7:10 pm |
quackconsumer
 Re: Best motor for my boat
That boat isn't big enough for a sd unless you go with one of those little copper heads
Thu Aug 11, 2011 7:15 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
MB Mini Lite 27 or MB 23 LA Special. Not gonna run anywhere close to how it does with 35 Evinrude no matter what you go with.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Thu Aug 11, 2011 7:19 pm |
quackconsumer
Thu Aug 11, 2011 7:26 pm |
Team Camo
Well, do you think it can handle a 23 GT? I thought it would, but you said no. If it will, then that's another option for the fella. I know 1st hand it would handle either of the 2 motors I mentioned. Not gonna get into the mine's better than yours BS, just trying to help the guy out.
Thu Aug 11, 2011 7:31 pm |
Sko
18 copperhead
_________________ 18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Thu Aug 11, 2011 7:33 pm |
mrmallard13
The transom is reinforced already. Had to do that to put the 35 on it. But you would suggest a new boat?
Thu Aug 11, 2011 7:35 pm |
Team Camo
If that's an option, then yes. Sell that boat as it is & buy a bigger boat. You'll be happier in the long run.
Thu Aug 11, 2011 7:40 pm |
quackconsumer
By handle do you mean stay afloat? Then yes. But will the hull hold up to the abuse of a sd over the long haul, and will he get optimum performance from that boat/ motor combination? Then No. Like I said if he is set on keeping that hull and wants to put a sd on it then the lighter copper heads would do best. But if he wants a larger sd with more hp, then he would be better off getting a longer boat.
Thu Aug 11, 2011 7:43 pm |
Team Camo
Thu Aug 11, 2011 7:48 pm |
OwenDickeson
I agree 101%
quackconsumer
You know I have to take my shots at mb when ever the opportunity presents itself.
Thu Aug 11, 2011 7:51 pm |
Team Camo
I know, it's part of the service agreement yall purchased.
Thu Aug 11, 2011 7:53 pm |
mrmallard13
Well damn. I was wanting to get a new Polaris rzr 900 but the way it sounds I need a new boat. Although I do hunt more places that are accessible by land than water.
Thu Aug 11, 2011 7:54 pm |
Team Camo
Airboat, solves both problems.
Thu Aug 11, 2011 7:55 pm |
mrmallard13
I'm not 100% but I don't think they allow airboats on public land in MS
Thu Aug 11, 2011 8:01 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
That boat will get torn to crap in short order no matter what mud motor you go with.
_________________ "We Are Products Of Our Decisions"
Tue Aug 16, 2011 9:34 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
If you are planning on limited use and want the razr you may want to look at buying a used longtail and then save up for a new boat motor combo. W/ the boat you have you will tear the hell out of it w/ a surface drive trying to run too fast and it won't perform that well.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Wed Aug 24, 2011 7:01 am |
SCmudder7071
If you hunt more land than water why worry about buying a $3-5k motor when you already want a rzr? Just use the boat til it falls apart and by then ull have more saved up for new rig. Plus u can use an outboard in weeds. Ever watch swamp people?
_________________ 1754 Extreme/LAProp Stage 2 GTR
Wed Aug 24, 2011 9:03 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
_________________ so many rivers, so little time
Wed Aug 24, 2011 3:12 pm |
Burch
Get a 23hp longtail for that boat and keep your outboard for fishing.You can probably pich one up for a little over a grand,used but in good shape.A surface drive will be faster but at 30 mph you can travel 10 miles in 20 minutes.At 15 mph you will cover this same 10 miles in 40 minutes.Save your money and wake up 20 minutes earlier.
Thu Aug 25, 2011 8:16 am |
