It is currently Wed Sep 24, 2025 12:06 am
Reply to topic  [ 16 posts ]
 GTR Lower Unit Rear Seal
Post GTR Lower Unit Rear Seal
d
Fri Aug 12, 2011 7:11 am
Post Re: GTR Lower Unit Rear Seal
Replace the seals and replace the screw.
Here is a threads where i explained the process of rebuilding a GTR lower unit.
viewtopic.php?f=3&t=20652
Fri Aug 12, 2011 7:28 am
Yeah you need to get that screw out and get a new one for it, always remove screw to put more grease in or you'll blow a seal everytime.....Rear seal is very easy to change
Fri Aug 12, 2011 12:10 pm
You mean SEALS Take'em
Fri Aug 12, 2011 12:11 pm
You do know that you have a backerd seal for that reason!! Instead of popping seals with grease cause people dont pull the screw out they designed it that way!! Get that stripped out screw out and you should be fine!! if it not leaking grease leave it alone !!
17x48 extreme stage 2 GTR
Fri Aug 12, 2011 3:02 pm
Thank fellas...........
Fri Aug 12, 2011 6:05 pm
I wouldn't have thought the bottom seal was trashed after pushing grease out. I fill my PD lower shaft wif grease until it squeezes out of the seal, per KP. I would think GTR used the same type seals on their lower to make them idiot proof, kinda.
18'x54"CC Hanko/ 36PD
Sun Aug 14, 2011 7:27 am
What tore the seal up is some wire I got wrapped up in the prop not from over pumping grease. I will be changing the seals as soon as I get in from work. Thanks for all ya'lls input.
Sun Aug 14, 2011 8:21 am
i agree. pull the screw when pumping grease in. otherwise you WILL blow the seals out.
Wed Sep 07, 2011 3:31 pm
Wed Sep 07, 2011 4:08 pm
if i remember correctly,the silver,round thingy that you gonna take off to get to the seals is backwerds threaded,but not sure on this.
Wed Sep 07, 2011 4:17 pm
And so it starts. :lol:
Wed Sep 07, 2011 4:29 pm
robin,id have to say,you deserve all the sh!t you get on here.I'd be too embarassed to log on if i was you! :?
Wed Sep 07, 2011 4:35 pm
Wed Sep 07, 2011 4:37 pm
apology accepted,now go argue with ddm.
Wed Sep 07, 2011 5:43 pm
Yes the bearing housing is left handed threads.
Thu Sep 08, 2011 8:29 am
