It is currently Sat Apr 04, 2026 8:04 pm
Reply to topic  [ 35 posts ]
 hill marine 7x5 prop
Post hill marine 7x5 prop
got a 7x5 prop for my 6.5 gdlt and noticed it was cupped. couldnt get it to rev up wouldnt go over 9mph. old prop i was running 11-12 mph with my old prop that ive had for 6yrs. so do i get a 7x5 with no cup or drop down to a 7x4? what would be better
Sun Aug 07, 2011 5:19 pm
Post Re: hill marine 7x5 prop
Anyone? Called and they said i should grind out the cup! they said that its a true 7x5 and the one that came one it may not of been! anyone grind on a prop before???? Suggestions??
Mon Aug 08, 2011 2:24 pm
Bigger motor.
Sat Aug 13, 2011 1:35 pm
if i had ur money id buy a bigger one
Sat Aug 13, 2011 5:07 pm
id tell them i want my money back or a diffrent prop did you ding it all up or just run in clear clean water?
Sun Aug 14, 2011 6:18 pm
Sun Aug 14, 2011 8:15 pm
not questioning that they know but i would find it hard to beleive that they would say try grinding the cup out and if that doesnt work send it back but hey maybe if he told them what he had andwhat it was going on you sure would think they would have set him up with the one he needed
Sun Aug 14, 2011 8:55 pm
I think Hill was just trying to get him on the water quicker. Takes a while to ship to Cali and then back again.
Mon Aug 15, 2011 8:12 am
yes it was clean water. they did tell me to grind it down. going to send it back. isnt the prop balanced? grinding it down is just a good way to ruin the seals and bushings.
Mon Aug 15, 2011 9:58 am
if hill would of stated that it had a cup or not like go-devil does. i wouldnt be having this issue!
Mon Aug 15, 2011 10:03 am
I got a 9x6 prop from hill a few years ago with too much cup. I took an angle grinder and worked on it. After 3 trips to the lake, I had enough ground off and it running good. Not real hard to do. A 30 minute job at worst.
Mon Aug 15, 2011 11:09 am
any vibration problems?
Mon Aug 15, 2011 2:07 pm
Nope. This was on a 27 gdlt. Just worked on side of the prop and measured it and did the same to the other side. Very unscientific, but the original prop ran 16.7. After the grind, it ran 19.8.
Mon Aug 15, 2011 2:56 pm
Mon Aug 15, 2011 5:54 pm
Guess Hill figures most people are mechanically inclined enough to use a grinder. Hell for the price of a slow devil prop you can by two Hill props.
Mon Aug 15, 2011 6:40 pm
this never was about hill it was about getting what you order but hey you want it to be about hill i guess and if i ordered id be sending it back for the reason of i ordered a prop cause they said it was what i needed not cause they said this will work after you grinde it thats no kind of company id like to deal with in my book
Mon Aug 15, 2011 7:16 pm
Mon Aug 15, 2011 8:59 pm
both say its a true 7x5 so why the diff? if i ordered from gd id have what it came with! and ive had good dealings with gd! you two act like your married
Mon Aug 15, 2011 9:26 pm
Mon Aug 15, 2011 9:30 pm
Would you like some sausage?
Mon Aug 15, 2011 9:34 pm
i think u have been smoking some of hills sausage with those last posts
Mon Aug 15, 2011 9:39 pm
and ur pom poms. u fix ur yet. 6.25 in dia. not bad for babying 6 yr old motor
Mon Aug 15, 2011 9:44 pm
well broke out the grinder. wonder how good i did?
Tue Aug 16, 2011 7:39 pm
ran it and it still has a little cup in it. my old prop is now only .5 mph faster now. going to run it and may grind some more
Sun Sep 11, 2011 2:42 pm
i think id be pissy about the whole issue :evil:
Sun Sep 11, 2011 6:52 pm
ya i am but it is what it is. ground some more and got 10mph with my son and hunting load
Sun Sep 11, 2011 9:24 pm
guess we will all have to remember this hassel....
Mon Sep 12, 2011 5:46 pm
ya. will go with a godevil next time
Mon Sep 12, 2011 8:44 pm
Hassle, sounds like you got educated. Next time go with a Hill7x4 cupped. the cup adds 1 pitch, so a 7x4 cupped will also bite better in mud.
Mon Sep 12, 2011 9:00 pm
Profile YIM
when i called he said he usually sends out their 6.5 dia prop for a 6.5hp lt! mines old one is down to 6.25 dia
Tue Sep 13, 2011 9:55 am
bobby even their website recommends 7x5 prop so something aint right
Tue Sep 13, 2011 5:54 pm
I know just messing with you, Hill props do work good, just takes a little knowledge of them to get one that works.
Tue Sep 13, 2011 10:43 pm
Profile YIM
I put a hill marine prop on my MM and its been a fantastic addition to my boat. I picked up nearly 8 mph top end when I replaced my old prop with a hill prop. I think he does great work. sorry to hear you had a problem with one of his props.
Thu Sep 15, 2011 1:13 am
Fri Sep 16, 2011 9:20 am
Meant compared to Godevil noncupped 7x5 versues Hill 7x4 cupped.
Sun Sep 18, 2011 3:56 pm
Profile YIM
